Vista - Converting String Pairs to IDictionary?
Old 04-29-2008   #1 (permalink)
coconet
I have a string like this
mystring = "color1:blue;color2:red";
I am tring to convert this into an IDictionary populated like this:
color1 blue
color2 red
My non-working syntax is
IDictionary<string,string> tempdict =
new Dictionary<string>(mystring.Split(';').ToDictionary()
).Split(':');
Help?
Old 04-29-2008   #2 (permalink)
Anthony Jones
Re: Converting String Pairs to IDictionary?
"coconet" <coconet@xxxxxx> wrote in message
news:6vre14tild7q6q18tab1va3v5tm8c0cgsd@xxxxxx
> color1 blue
> color2 red
> ).Split(':');
Try this:- (untested)
IDictionary<string,string> tempdict = new Dictionary<string,string>()
foreach(string[] item in splitItems(mystring.Split(';')))
tempdict.Add(item[0], item[1]);
private static IEnumerable<string[]> splitItems(string input)
foreach (string item in input.Split(';'))
yield return item.Split(':');
Anthony Jones - MVP ASP/ASP.NET
Old 04-30-2008   #3 (permalink)
coconet
Thanks for the help. Unfortunately I am working with an instance class
so i can't do an extension method (I think that's what you're doing).
On Tue, 29 Apr 2008 22:10:00 +0100, "Anthony Jones"
>> color1 blue
>> color2 red
>> ).Split(':');
Old 04-30-2008   #4 (permalink)
Anthony Jones
news:lgvg14lsnaip1s5sq8pg2r7sirqpcfl8f1@xxxxxx
Its not an extension method.
Just because you are working on code designed to run as an instance method
doesn't mean it can't call static methods. I tend to make any method that
doesn't need instance members static. As a private method it doesn't really
matter that much whether its marked as static or not. It just seems more
correct to me.
> >> color1 blue
> >> color2 red
> >> ).Split(':');
Reading and assigning key/value pairs from XML PowerShell
Cast from one generic IDictionary to another .NET General
winrm nested key=value pairs PowerShell
Converting Get-ChildItems to string for processing. PowerShell
Converting date time format to string format PowerShell
