Vista - System.Resources.MissingManifestResourceException
Old 04-30-2008   #1 (permalink)
Peri
Dear All,
My Scenario is this:
I am having a Windows Application called XXX.Win, two DLLs named XXX.Biz and
XXX.ActiveComponent.ACInteractive and using VS 2005 with.NET framework 2.0.
In all the there projects I am havaing a resouce file named resouce.resx
(Defaul file created by VS 2005) and all the three projects are NOT intended
to be Multi-Linugal. These 3 resouce files are mainly used to take the
messages and display it to the user instead of hard-coding it.
I have referred the XXX.ActiveComponent.ACInteractive dll in XXX.Biz dll
I have referred the XXX.ActiveComponent.ACInteractive dll and XXX.BIZ dll in
XXX.Win application.
Few weeks back it was running well without any issues. But now I am getting
this error called System.Resources.MissingManifestResourceException with the
following description while accessing the resouce file.in
XXX.ActiveComponent.ACInteractive dll.
"Could not find any resources appropriate for the specified culture or the
neutral culture. Make sure "XXX.Biz.Resources.resources" was correctly
embedded or linked into assembly "ActiveComponent" at compile time, or that
all the satellite assemblies required are loadable and fully signed."
Can anyone help me out on how to resolve this issue?
Thanks and Regards,
Peri
Old 04-30-2008   #2 (permalink)
Cor Ligthert[MVP]
Re: System.Resources.MissingManifestResourceException
Peri,
In my opinion are these answers just like we all make sometimes, there is a
manager who says there should be an answer whatever it is. I have seen them
often, and they sound for me sometimes the same as. "It can be that it is
raining and this can be the reason for this error".
However, sometims I then restart the IDE or restart the computer and it is
resolved.
It cannot come automaticly as you did not do anything.
What I do if I then not succeed is simple make a small new project, import
(set the resources) then the DLL's and see if the problem is then the same.
Cor
"Peri" <peri@xxxxxx> schreef in bericht
news:OveJZ1oqIHA.1772@xxxxxx
Quote:
> Dear All,
> and XXX.ActiveComponent.ACInteractive and using VS 2005 with.NET framework
> 2.0.
> intended to be Multi-Linugal. These 3 resouce files are mainly used to
> take the messages and display it to the user instead of hard-coding it.
> in XXX.Win application.
> getting this error called
> System.Resources.MissingManifestResourceException with the following
> that all the satellite assemblies required are loadable and fully signed."
> Thanks and Regards,
> Peri
Out of system resources Vista account administration
AV programs system resources System Security
Explorer hogging system resources Vista performance & maintenance
Is there some new limit to system resources Vista performance & maintenance
Vista Using too much System Resources Vista General
