Vista - Anchor listbox problem
Old 04-30-2008   #1 (permalink)
Rotsey
I have a Listbox in a Panel of SplitContainer.
I want to anchor it so the listbox grows/shrinks vertically with the
resizing the splitcontainer.
This is my code
What happens is it sizes the listbox horizontally about nearly the same size
as the split container width.
_TableList = new MdsListBox();
_TableList.Name = "TableList";
_TableList.Left = 10;
_TableList.Top = 40;
_TableList.Width = 150;
_TableList.Height = 100;
_TableList.Anchor = (AnchorStyles.Left | AnchorStyles.Right |
AnchorStyles.Bottom | AnchorStyles.Top);
I want the size of the listbox set here retained.
rotsey
Old 04-30-2008   #2 (permalink)
Marc Gravell
Re: Anchor listbox problem
same size
If you only want it to grow vertically, then anchor it left or right,
but not both.
Marc
Old 04-30-2008   #3 (permalink)
Rotsey
that worked.....but don't know why
"Marc Gravell" <marc.gravell@xxxxxx> wrote in message
news:ejy7hjpqIHA.1768@xxxxxx
> same size
> If you only want it to grow vertically, then anchor it left or right, but
> not both.
> Marc
Old 04-30-2008   #4 (permalink)
Marc Gravell
By anchoring it left | right, you are telling it to keep the left edge a
fixed distance from the container's left edge, and the right edge a
fixed distance from the container's right edge. Ihis means that it will
grow and shrink horizontally along with the container. If you don't want
it to track (grow and shirnk) the right hand edge, then don't anchor it
to the right hand edge.
Marc
Old 04-30-2008   #5 (permalink)
Rotsey
but now the listbox is anchored but part is not visiible under the second
panel
the listbox is the top panel
why can't it just stay where i set it to.....is this rocket science MS?
"Rotsey" <malcolm_smith@xxxxxx> wrote in message
news:%23gaj18pqIHA.4544@xxxxxx
>> same size
>> not both.
>> Marc
Old 04-30-2008   #6 (permalink)
Marc Gravell
I don't understand what you mean "part is not visible under the second
panel"... it is starting at the height you give it: so give it the right
height! Or alternatively, set Dock to Left (much easier than managing
all the details manually).
A quick (C# 3) demo:
using System;
using System.Drawing;
using System.Windows.Forms;
static class Program
[STAThread]
static void Main()
Application.EnableVisualStyles();
Application.Run(new Form
Text = "Split Demo",
Controls =
new SplitContainer() {
Dock = DockStyle.Fill,
Orientation = Orientation.Horizontal,
Panel1 = {
BackColor = Color.Green,
Controls = {
new ListBox {
Dock = DockStyle.Left,
IntegralHeight = false,
BackColor = Color.Red,
Items = {
"Foo", "Bar", "Blip", "Blap", "Bloop"
}, Panel2 = {
BackColor = Color.Blue
Old 04-30-2008   #7 (permalink)
Rotsey
That does not compile
But it is not what I want
I have more just that control in the top panel of the splitcontainer.
So I have set the poistion and size of where I want the lb to start
and set the Anchor.Left , top bottom as you say.
But the bottom of the lb is not visible it is under the bottom panel
any more info would be grateful Marc.
news:%23BVS6OqqIHA.3804@xxxxxx
>height! Or alternatively, set Dock to Left (much easier than managing all
> using System;
> [STAThread]
> static void Main()
> Controls =
> Panel1 = {
> Controls = {
> new ListBox {
> Items = {
> }, Panel2 = {
Old 04-30-2008   #8 (permalink)
Marc Gravell
Yes it does - with a C# 3 compiler (I did state it was C# 3...).
OK; how are you setting up the form? Are you using the Visual Studio
designer? If so, you should be able to simply resize (drag) the ListBox
as needed, and then set the Anchor...
Are you doing something different?
Marc
Old 04-30-2008   #9 (permalink)
Rotsey
I have a farily busy form
A splitContainer horizontal
In the right panel a tab control
then in a tap page I have my split container vertical
The in the top panel a another panel
It is in this panel of that I have my lb and other controls
Everything from the tabcontrol is added dymanically.
One issue I did have was setting the splitterdistance of the vertical
control
did not seem right I had to set it to 10. The panel hieght with its control
is actaully 145
I changed lb height to 5 and it is still actually about 100 and the bottom
is not visible.
Any ideas?
news:OMDixbqqIHA.1164@xxxxxx
> designer? If so, you should be able to simply resize (drag) the ListBox as
> Marc
Old 04-30-2008   #10 (permalink)
Rotsey
I can email you a screen dump if you need to see it
news:e6CSCjqqIHA.3680@xxxxxx
> control
> control is actaully 145
> is not visible.
> Any ideas?
>> Marc
click to url with anchor Vista mail
Easy to get handle from listbox. How to get listbox from handle? .NET General
windows live mail and anchor links Live Mail
