Vista - Detecting if an application is installed on a system
Old 05-05-2008   #1 (permalink)
Greg Smith
I have a series of applications that assume other applications are
installed. Is there a way to detect the installation of a specific
application?
Any help is greatly appreciated.
Old 05-06-2008   #2 (permalink)
Family Tree Mike
RE: Detecting if an application is installed on a system
There is no general rule to identifying whether a particular application is
installed. Some broadcast their availability by a registry key, others
don't. You may want to post the software title you are testing for and
someone may recognize a test that will identify the presence of it on the
system.
> application?
Old 05-06-2008   #3 (permalink)
Greg Smith
Re: Detecting if an application is installed on a system
These do. How would you identify the app?
Old 05-06-2008   #4 (permalink)
Cor Ligthert[MVP]
By reading the registry with the proper rights, what is not always the
situation.
Your question is a little bit from 1980, now you have to be more precice in
what your searching and create proper security rigths to see that.
Cor
Old 05-06-2008   #5 (permalink)
Family Tree Mike
"Greg Smith" wrote:
For example, the following code finds the current version of Java, and the
install path to it:
string key = @"SOFTWARE\JavaSoft\Java Runtime Environment";
Microsoft.Win32.RegistryKey keyJRE =
Microsoft.Win32 .Registry .LocalMachine .OpenSubKey (key, false);
string version = (string) keyJRE.GetValue("CurrentVersion");
Microsoft.Win32.RegistryKey keyJREactive = keyJRE.OpenSubKey(version);
string javahome =
System.IO.Path.Combine((string) keyJREactive.GetValue("JavaHome"),
@"bin\java.exe");
return javahome;
Old 05-06-2008   #6 (permalink)
Family Tree Mike
Sorry... Add checks for whether the keys exist of course!
"Family Tree Mike" wrote:
Quote:
> install path to it:
> string javahome =
> @"bin\java.exe");
> return javahome;
Detecting system shutdown. PowerShell
Detecting system shutdown PowerShell
System is not detecting Mic Vista hardware & devices
System stops detecting mic Vista networking & sharing
detecting changes to the system Vista account administration
