| | MSBuild works everywhere except on one problem machine -Help!!!! All, We have an application that builds fine under visual studio, even on the "problem" machine. We are trying to use MSBuild from the command line to build that application. We use the following command c:\windows\microsoft.net\framework\v3.5\msbuild wordagent.csproj /p:configuration=release This also works fine on every machine except for the "problem" machine. On this "problem" machine we get the error at the end of this post. If we modify the WordAgent.csproj.user as shown below msbuild works fine on the "problem" machine. Of course, this is not the solution we want. Any help would be appreciated. If you live in the West Chester Pa. area, i will buy you a beer if you help us solve this!!!! : ) <Project xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> <PropertyGroup> <ProjectView>ShowAllFiles</ProjectView> <PublishUrlHistory>http://localhost/WordDLPAgent/</PublishUrlHistory> <InstallUrlHistory> </InstallUrlHistory> <SupportUrlHistory> </SupportUrlHistory> <UpdateUrlHistory> </UpdateUrlHistory> <BootstrapperUrlHistory> </BootstrapperUrlHistory> <FallbackCulture>en-US</FallbackCulture> <VerifyUploadedFiles>true</VerifyUploadedFiles> we added this an it works fine <OutputPath>bin\Release</OutputPath> </PropertyGroup> <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' "> <StartArguments>debug\XmlExamples\TLF001.xml C:\WordAgentTest\JobError\Error.txt true false</StartArguments> <StartWorkingDirectory>C:\WordAgent\bin\</StartWorkingDirectory> </PropertyGroup> <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' "> <StartWorkingDirectory> </StartWorkingDirectory> </PropertyGroup> </Project> -------- Error -------- C:\WordAgentBuild>buildagent C:\WordAgentBuild>c:\windows\microsoft.net\framework\v3.5\msbuild wordagent.csproj /p:configuration=release Microsoft (R) Build Engine Version 3.5.21022.8 [Microsoft .NET Framework, Version 2.0.50727.1433] Copyright (C) Microsoft Corporation 2007. All rights reserved. Build started 5/13/2008 3:28:57 AM. Project "C:\WordAgentBuild\wordagent.csproj" on node 0 (default targets). C:\WINDOWS\Microsoft.NET\Framework\v3.5\Microsoft.Common.targets(529,9): error : The OutputPath property is not set for this project. Please check to make sure that you have specified a valid Configuration/Platform combination. Configur ation='release' Platform='MCD' Done Building Project "C:\WordAgentBuild\wordagent.csproj" (default targets) -- FAILED. Build FAILED. "C:\WordAgentBuild\wordagent.csproj" (default target) (1) -> (_CheckForInvalidConfigurationAndPlatform target) -> C:\WINDOWS\Microsoft.NET\Framework\v3.5\Microsoft.Common.targets(529,9): error : The OutputPath property is not set f or this project. Please check to make sure that you have specified a valid Configuration/Platform combination. Config uration='release' Platform='MCD' 0 Warning(s) 1 Error(s) Time Elapsed 00:00:00 |
| | Build issue I am also having the same problem. Code compiles everywhere except one computer with Duo 2 processor. Were you able to compile yours? Thanks. Original Post MSBuild works everywhere except on one problem machine -Help!!!! - scott ocamb 13-May-08 04:54:48 All, We have an application that builds fine under visual studio, even on the We are trying to use MSBuild from the command line to build that application. We use the following command c:\windows\microsoft.net\framework\v3.5\msbuild wordagent.csproj /p:configuration=release This also works fine on every machine except for the "problem" machine. On this "problem" machine we get the error at the end of this post. If we modify the WordAgent.csproj.user as shown below msbuild works fine on the "problem" machine. Of course, this is not the solution we want. Any help would be appreciated. If you live in the West Chester Pa. area, i will buy you a beer if you help us solve this!!!! : ) |
| MSBuild Project files and BuildUri | .NET General | |||
| MSBuild script for Getlatest cource code | .NET General | |||
| MSBuild TargetOutputs Question. | .NET General | |||
| Building a project that uses PowerShell using MSBuild | PowerShell | |||
| Program written in Access 2003 works on XP machine, but not Vista | Vista General | |||
