| | Printer server problem? Last month, i updated my server 2003 to sp2. After update done, it have a problem, the folder C:\WINDOWS\system32\spool\PRINTERS is exist many print temp files and can not delete when print out automatically. And i look its printer properties, there are many documents and its status is "Deleting-Printed". This is a serious problem if i do not take care then our system dick space will be insufficient or system crash. If someone can fix this problem? regards, |
| | Re: Printer server problem? You might want to try posting your question to a newsgroup with "Windows" in the description. This is a .Net programming newsgroup. RobinS., "glaziz" <glaziz@xxxxxx> wrote in message news:C72D4624-6AAE-430F-833F-60197EBBD4BB@xxxxxx Quote: > Last month, i updated my server 2003 to sp2. After update done, it have a > problem, > the folder C:\WINDOWS\system32\spool\PRINTERS is exist many print temp > files > and can not delete when print out automatically. And i look its printer > properties, there are many documents and its status is "Deleting-Printed". > This is a serious problem if i do not take care then our system dick space > will be insufficient or system crash. If someone can fix this problem? > regards, > |
| Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) | Vista General | |||
| Windows 2008 print server at terminal services - printer driver problem | Vista print fax & scan | |||
| Problem printing through a printer server | Vista print fax & scan | |||
| Lexmark Printer / Error problem communicating with printer | Vista print fax & scan | |||
| Printer Server Problem | Vista networking & sharing | |||
