| | Passing passwords to Web site Hi, I'm using this very simple code to open a web site and it works perfectly. The site requires that I enter a User Name and password. I'd like to send those with the application but after making all sorts of trials to pass the values as parameters - nothing happens. Can some one guide how to to this - or say it's not possible? Regards Laurie Public Class Form1 Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load WebBrowser1.Navigate("http://WebAddress/?disablechatbrowsercheck=0") End Sub End Class |
| | RE: Passing passwords to Web site Unless the server setting is turned on allowing you to pass username and password along with the string (look at the string after you successfully log in) you will have to do it manually. I say have to, which isn't quite true, but it is easier. Look at the source code and find the name of the textbox for each, and the button name. I use this sub to set text into textboxes, just pass in the textbox name and the text you want in it: (wb is the name of my webbrowser) Sub setText(ByVal _inputName, ByVal _text) 'given an input name and text, the textbox will be populated with _text Dim inputs As HtmlElementCollection = wb.Document.GetElementsByTagName("Input") Dim input As HtmlElement For Each input In inputs If input.Name = _inputName Then input.InnerText = _text End If Next End Sub Do that, and then use this sub for clicking a button, just pass in the button name. Keep in mind this is sometimes case sensitive: Sub clickButton(ByVal _btnName) 'clicks a button with the supplied name Dim buttons As HtmlElementCollection = wb.Document.GetElementsByTagName("input") Dim button As HtmlElement For Each button In buttons If button.Name.Contains(_btnName) Then button.InvokeMember("Click") End If Next End Sub Hope that helps -- -John Please rate when your question is answered to help us and others know what is helpful. "Laurie Comerford" wrote: Quote: > Hi, > > I'm using this very simple code to open a web site and it works perfectly. > > The site requires that I enter a User Name and password. > > I'd like to send those with the application but after making all sorts > of trials to pass the values as parameters - nothing happens. > > Can some one guide how to to this - or say it's not possible? > > > Regards > > Laurie > > Public Class Form1 > > Private Sub Form1_Load(ByVal sender As Object, ByVal e As > System.EventArgs) Handles Me.Load > > WebBrowser1.Navigate("http://WebAddress/?disablechatbrowsercheck=0") > > End Sub > > > End Class > |
| Just passing along some information | Vista mail | |||
| Passing a connection through. | Network & Sharing | |||
| Site forum site vista tutorials do not play | General Discussion | |||
| passing whole objects | PowerShell | |||
| NTLM Passwords Linux NAS passwords | Vista networking & sharing | |||
