| | Read Byte Array into String for Delimiting? I have a byte[] that came from a network resource. I would like to read this "line by line" and split it on tab character. The bytes are ASCII encoded, so there should be real EOL markers. I have my MemoryStream on the bytes, now how can I quickly read it? I can't use LINQ because I am working strictly with an instance Type. Thanks. .NET 3.5. |
| | Re: Read Byte Array into String for Delimiting? Use Encoding.ASCII.GetString () on the byte [] or open a StreamReader or a TextReader on your MemoryStream.. /LM "coconet" <coconet@xxxxxx> wrote in message news:1dce34dj47g7l3mhnksaiomromqafl8cd0@xxxxxx Quote: > > I have a byte[] that came from a network resource. I would like to > read this "line by line" and split it on tab character. The bytes are > ASCII encoded, so there should be real EOL markers. I have my > MemoryStream on the bytes, now how can I quickly read it? > > I can't use LINQ because I am working strictly with an instance Type. > > Thanks. .NET 3.5. > > > > |
| | Re: Read Byte Array into String for Delimiting? The initial byte[] is huge, so I'd rather not turn it into a single giant string with GetString(). I think what I want to do is read the byte[] until I hit Environment.NewLine, then re-read the byte[] into a tempbyte[] with an offset from n to n+read. Then I can to GetString() on that piece. But I don't know how to code that. I want to use Read or ReadBytes, maybe BeginRead() to make it Async so I can report what I'm working on. But I don't know how the code could look. Help with any guidance code? Thanks. On Sat, 24 May 2008 05:03:08 +0200, "Luc E. Mistiaen" <luc.mistiaen@xxxxxx> wrote: Quote: >Use Encoding.ASCII.GetString () on the byte [] or open a StreamReader or a >TextReader on your MemoryStream.. > >/LM > >"coconet" <coconet@xxxxxx> wrote in message >news:1dce34dj47g7l3mhnksaiomromqafl8cd0@xxxxxx Quote: >> >> I have a byte[] that came from a network resource. I would like to >> read this "line by line" and split it on tab character. The bytes are >> ASCII encoded, so there should be real EOL markers. I have my >> MemoryStream on the bytes, now how can I quickly read it? >> >> I can't use LINQ because I am working strictly with an instance Type. >> >> Thanks. .NET 3.5. >> >> >> >> |
| | Re: Read Byte Array into String for Delimiting? coconet <coconet@xxxxxx> wrote: Quote: > The initial byte[] is huge, so I'd rather not turn it into a single > giant string with GetString(). I think what I want to do is read the > byte[] until I hit Environment.NewLine, then re-read the byte[] into a > tempbyte[] with an offset from n to n+read. Then I can to GetString() > on that piece. But I don't know how to code that. I want to use Read > or ReadBytes, maybe BeginRead() to make it Async so I can report what > I'm working on. But I don't know how the code could look. (plus a bit for buffering). -- Jon Skeet - <skeet@xxxxxx> Web site: http://www.pobox.com/~skeet Blog: http://www.msmvps.com/jon.skeet C# in Depth: http://csharpindepth.com |
| Convert Byte() to string | VB Script | |||
| Fast byte array comparison for ordering purposes | .NET General | |||
| creating a byte array to read in image | PowerShell | |||
| Creating a byte array | PowerShell | |||
| String to Array | PowerShell | |||
