| | System Sockets and Winsock in VB6 Hi, I've read a lot about the use of system sockets in Vb.net instead of winsock fine but how do i get a vb.net service running on a 2003 server to send a message to a desktop vb6 exe that can only use winsock? So the service needs to send a message to the PC via some port say 8000. The service knows the IP address of the PC also. The system socket code sends the message and the VB6 exe has connected to the server on port 8000 but gets no message. Am I missing the point here? is there something different about the raw data passed by system sockets that winsock cannot interpret. Has anyone managed to do this? BTW rewriting the desktop VB6 exe is not an option as it is massive and very complicated and not needed if the exe can receive the message on the designated port. Can anyone help or suggest some other method. As a last resort i may get the service to talk to an VB6 activex dll to get it to send the message but surely this is un-necessary... Thanks Martin |
| Application Messaging over Sockets | .NET General | |||
| Slow streaming TCP sockets | .NET General | |||
| Problems sending data with System.Net.Sockets.Socket | PowerShell | |||
| Connection problems using TCP/IP sockets | Vista hardware & devices | |||
| Front and back panel sound sockets | Vista General | |||
