Vista - .NET Fx 3.0 installation fails with a 16-bit MS-DOS subsystem erro
Old 06-04-2008   #1 (permalink)
ondrej421
Hi everyone,
My application's NSIS based installer runs dotnetfx3.exe before it runs
msiexec to install the actual application.
On a large number of XP computers, dotnetfx3.exe fails about half way
through with a 16-bit MS-DOS subsystem error.
The message box that appears claims:
C:\DOCUME~1\USER\LOCALS~1\Temp\DOTNET~1.EXE
NTVDM CPU contains an invalid instruction
CS:0fa1 ... Click Close to terminate the application.
I have been unable to tie the problem to any particular XP build,
architecture, CPU, locale, ...
Can anyone think of what this could be?
Thanks in advance!
Installation fails Live Mail
Installation of SP1 fails Vista General
New installation fails? Vista installation & setup
Installation Fails. How Report Vista installation & setup
Pre-RC1 Installation fails Vista installation & setup
