On Jun 5, 5:31*pm, Stefan Pascal <stefan.pas...@xxxxxx> wrote:
> Hello.
> I have a very strange problem on my system with running C#
> applications from a longer than usual (>127 chars) path. I was able to
> reproduce the following 2 cases:
> 1. Socket s = new Socket(AddressFamily.InterNetwork,
> SocketType.Stream, ProtocolType.Tcp); // <-- crashes here #1
> 2. SqlConnection con = new SqlConnection("Persist Security
> Info=False;server=MyServer\\MyInstance;database=MyDataBase;Connect
> Timeout=30;Trusted_Connection=True;");
> con.Open(); // <-- crashes here #2
> #1 crash shows the message: "WSAStartup cannot function at this time
> because the underlying system it uses to provide network services is
> currently unavailable."
> #2 crash shows the message: "An error has occurred while establishing
> a connection to the server. *When connecting to SQL Server 2005, this
> failure may be caused by the fact that under the default settings SQL
> Server does not allow remote connections. (provider: SQL Network
> Interfaces, error: 26 - Error Locating Server/Instance Specified)"
> My workstation settings:
> Operating System: Windows XP SP2
> Programming Environment: Microsoft Visual Studio 2005 Team Edition for
> Software Developers (8.0.50727.42 RTM.050727-4200)
> .NET Framework: .NET Framework 1.1, .NET Framework 2.0 Service Pack 1
> If i run *any C# application* from a path that exeeds 127 characters
> (including the file name) - it crashes. For example: C:\Documents and
> Settings\user123.xCOMPANY\Local Settings\Apps\2.0\HMTCX95T.RXV
> \9CKLQ85R.AXB
> \appl..tion_6e98555c88572fe0_0001.0002_47eaa25a8a47e226\TestSPExecTestSPExe*cTestSPExecTestSPExec.exe
> If i change the file name and/or the path to make it less or equal to
> 127 characters, everything works fine! For example: C:\Documents and
> \9CKLQ85R.AXB\TestSPExecTestSPExecTestSPExec.exe
> Does anyone have any clue about what the problem might be? I wouldn't
> like to reinstall my workstation since i have a lot of SDKs installed
> and configured, and it would take a lot of time to reconfigure
> everything from scratch.
> Thank you! I forgot to mention that for the second case (SQLConnection exception)
the connection string is perfectly ok. As i said, the same EXE moved
(copied) to another (shorter) directory (path) or renamed in the same
directory runs without any problem! So it is a problem related to the
executable full path lenght.
Any ideas? Thank you.
