Vista - difference between HttpWebResponse and WebResponse?
Old 06-05-2008   #1 (permalink)
buu
what is it?
Am I right that one of differences is that HttpWebResponse has property for
checking if web page is relocated?
Old 06-06-2008   #2 (permalink)
Marc Gravell
Re: difference between HttpWebResponse and WebResponse?
Well, WebResponse is the abstract base-class for a family of similar
classes - of which HttpWebResponse is just one. There are also classes
for ftp and unc operations.
HttpWebResponse is used for http[s] based operations, so it defines
things relevant for http (http-version, http-status-code, etc).
Marc
I can't believe the difference Vista General
what is difference between VB and VB.net VB Script
difference between 64 bit and 32 bit os Vista General
Difference between 32 & 64? General Discussion
32 or 64 bit? What's the difference? Vista installation & setup
