Vista - Weird dataset.getchanges problem
Old 06-05-2008   #1 (permalink)
John Sheppard
Hello there,
I have the following code; I do this as a work around for a
dataset.haschanges method which doesnt appear to work correctly either
For Each dt As DataTable In myDs.Tables
If Not dt.GetChanges(DataRowState.Added) Is Nothing Then hasChanges=true
If Not dt.GetChanges(DataRowState.Modified) Is Nothing Then
hasChanges=true
If Not dt.GetChanges(DataRowState.Deleted) Is Nothing Then
hasChanges=true
Next
On some (not all) of my datatables in the dataset, Visual Studio is claming
that certain columns do not exist when I hit the first dt.getchanges line.
The column that it claimes does not exist are not in the datatable
(according to the dataset visualiser)
I have tried regenerating my dataset.
Does anyone know what could be going on? I cant figure it out...
Thank you
John
Old 06-06-2008   #2 (permalink)
Cor Ligthert[MVP]
Re: Weird dataset.getchanges problem
John,
This sound strange
The GetChanges creates a real copy of your datatable, I have never seen
this, maybe it uses XML serializing behind the scene and then avoid
probably empty columns, can you check that? Would be interesting.
Cor
"John Sheppard" <spam@xxxxxx> schreef in bericht
news:g2ace90115q@xxxxxx
Quote:
> Hello there,
> hasChanges=true
> hasChanges=true
> hasChanges=true
> Next
> claming that certain columns do not exist when I hit the first
> dt.getchanges line. The column that it claimes does not exist are not in
> the datatable (according to the dataset visualiser)
> Thank you
> John
Old 06-10-2008   #3 (permalink)
John Sheppard
Thanks cor, I will check that out and report back. Sorry for the delay, it
was a long weekend here.
John
"Cor Ligthert[MVP]" <notmyfirstname@xxxxxx> wrote in message
news:B2751449-8232-4891-BBFF-0387D6BEA41A@xxxxxx
Quote:
> John,
> This sound strange
> claming
> Cor
Quote:
>> Hello there,
>> hasChanges=true
>> hasChanges=true
>> hasChanges=true
>> Next
>> Thank you
>> John
Old 06-11-2008   #4 (permalink)
John Sheppard
Hi Cor,
There are empty columns, but there are also empty columns in datatables that
work....that is, I cant see that they directly relate.
I don't know why, but if I do a merge into a clean dataset beforehand it
works.
It's threaded code and the original dataset comes from a baseform. These
things shouldnt really matter I dont think but maybe that has something to
do with it.For now I'm content to use the workaround below.
'This worked
Dim test As New dsBMS
test.Merge(myDs)
For Each dt As DataTable In test.Tables
hasChanges=true
hasChanges=true
Next
'This didnt work
hasChanges=true
hasChanges=true
Next
Thanks Cor
John
Quote:
> John,
> This sound strange
> claming
> Cor
Quote:
>> Hello there,
>> hasChanges=true
>> hasChanges=true
>> hasChanges=true
>> Next
>> Thank you
>> John
Weird - Very weird annoying problem General Discussion
weird problem Vista General
weird problem Vista performance & maintenance
