Vista - hi, how to read bits from CImage class
Old 06-07-2008   #1 (permalink)
Baby Lion
I use the getbits like this ,but when I read half of the image ,the
error occur, could you tell me why this happen , and do I need to lock
the memory of CImage.GetBits() before I use it,
thanks
w = image.GetWidth();
h = image.GetHeight();
int nClrCount = image.GetBPP()/8;
BYTE * pImageData = (BYTE *)image.GetBits(); ///??? do I need to lock
it ? and how to lock it?
int Pitch = image.GetPitch();
if( nClrCount == 3)
for( int y = 0; y<h ; y++)
for( int x = 0 ;x<w; x++)
WORD hue,luminance,saturation;
BYTE bRed,bGreen,bBlue;
BYTE * p = pImageData + (y*w+x)*3; //////?????right?
/// the runtime error
happened here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bRed = *p;
bGreen = *(p+1);
bBlue = * (p+2);
COLORREF color = RGB(bRed, bGreen, bBlue);
ColorRGBToHLS(color,&hue,&luminance,&saturation);
if( luminance > 240)
cout<<"ERROR: luminance>240"<<endl;
throw exception();
if( Pitch < 0 )
PgmM[h-y-1][x] = luminance /240.0;
}else{
PgmM[y][x] = luminance / 240.0;
When a class is both an inherited class of another, and alsoimplements an interface method .NET General
Need help in 32 bits to 64 bits switching... General Discussion
Vista 32 bits to Vista 64 bits without loosing apps. Vista installation & setup
Internet Explorer 7 (32-bits) keeps on freezing wile the 64-bits works OK in Vista 64 Vista General
Why does x86 mean 64 bits while x32 means 32 bits? Vista General
