| | Intellisense and C# / managed C++ DLL problem. Hi all. I'm just struggling with migration of my C# project that also uses managed DLL wrapper. Now, the wrapper is referred to via references->project on C# site. My sneaky suspicion is the problem is somewhere at the joint of DLL and C#, though this may be not a valid guess. All compiles fine as it used to, though the C# intellisense comes up with the following error when changing Debug to Release and/or x86 to x64: There was a problem reading metadata from '{BF5AC628-BB8E-4B99-8601-8CFE58405E9E}' ('The system cannot find the file specified.'). IntelliSense may not work properly until the solution is reloaded. Can you think of why there is any problem and/or how to find the referred '{BF5AC628-BB8E-4B99-8601-8CFE58405E9E}'? The compiler version - Microsoft Visual Studio 2008. Cheers, Peter. |
| | Re: Intellisense and C# / managed C++ DLL problem. > Can you think of why there is any problem and/or how to find the Quote: > referred '{BF5AC628-BB8E-4B99-8601-8CFE58405E9E}'? The compiler version > - Microsoft Visual Studio 2008. project. So as far as I gather correctly, C# intellisense cannot read metadata from the vcproj of the DLL library. Any more help out there? Ta |
| | Re: Intellisense and C# / managed C++ DLL problem. > Erm, the listed above reference is a UID of the managed VC++ DLL Quote: > project. So as far as I gather correctly, C# intellisense cannot read > metadata from the vcproj of the DLL library. Any more help out there? scratch would help and it turns out it does not. Now, my suspicion is the Intellisense provided with MsVS2008 differs from its counterpart in previous versions to some extent. |
| Build My Own Intellisense | .NET General | |||
| Configuration of Intellisense. | .NET General | |||
| Problem registering managed component with COM | .NET General | |||
| VS 2005 intellisense problem | Vista General | |||
| Managed to fix power off and reboot problem | Vista General | |||
