| | help i have genuine MS on my computer and this download that was somwhow loaded on to my computer says i do not or that i may be at risk. how do i get rid of this pop up that appears when i turn my computer on |
| | Re: help deb wrote: Quote: > i have genuine MS on my computer and this download that was somwhow loaded on > to my computer says i do not or that i may be at risk. how do i get rid of > this pop up that appears when i turn my computer on windows security center, you eitehr have to do something about it, or configure it not to show the warning. You can for example tell it that it should not look for virus protection as you may have an antivirus program that it can not recognise. If it's some kind of malware that is showing a banner, you should get some program like AdAware, Hijack This or Spybot Search & Destroy. Anyway, "help" is not a useful subject for a thread. Also, questions like this should go in some operating system related newsgroup, rather than a software development newsgroup. -- Göran Andersson _____ http://www.guffa.com |
