Vista - printer problem
Old 06-12-2008   #1 (permalink)
bigbaddave
printer problem
My printer stopped printing and when I went to the printers and faxes, it
shows my printer to be "offline". How can I get it switched to "online"
Old 06-13-2008   #2 (permalink)
PvdG42
Re: printer problem
"bigbaddave" <bigbaddave@xxxxxx> wrote in message
news3D881F7-F30A-483B-A973-7810A4A42126@xxxxxx
As this has nothing to do with .NET programming and you don't mention which
version of Windows you are using, only the most general advice can be
provided.
Try removing the printer through Device Manager, then reboot to allow
Windows to "rediscover it". Try uninstalling all printer software and
drivers, detach the printer then reboot. Reinstall from scratch.
As you don't mention what OS you are running, it's impossible to direct you
to a specific group for your question, but this .NET programming group isn't
it.
As you appear to be using a web interface, start here to find an appropriate
group:
http://www.microsoft.com/communities...s/default.aspx
Click the + beside your language. then scroll down to Windows. In Windows,
open the category for your version of Windows, then find a group there to
post in.
Problem with Dell printer after installation of Vista SP2 (printer prints an extra page) Vista General
printer problem to domain's printer Vista General
Printer problem Vista General
Add printer problem Vista print fax & scan
Lexmark Printer / Error problem communicating with printer Vista print fax & scan
