| | Is try-catch block a way to prevent a crash? Hi, I've found that if I wrap my code with a try-catch block in the fashion illustrated below, it'll do what is specified in the catch section instead of crashing. Could anyone confirm that this is true? If it's true, I'll modify every single method in my program to wrap it with a try-catch block to prevent it from crashing. FYI, the try-catch block I mentioned is as below: void SomeMethod() { try { // Do something } catch (Exception e) { logger.Write (e.Message); } } |
| | Re: Is try-catch block a way to prevent a crash? On Thu, 12 Jun 2008 19:12:36 -0700 (PDT), Curious <fir5tsight@xxxxxx> wrote: Quote: >Hi, > >I've found that if I wrap my code with a try-catch block in the >fashion illustrated below, it'll do what is specified in the catch >section instead of crashing. Could anyone confirm that this is true? > >If it's true, I'll modify every single method in my program to wrap it >with a try-catch block to prevent it from crashing. > >FYI, the try-catch block I mentioned is as below: > >void SomeMethod() >{ > try > { > // Do something > > } > catch (Exception e) > { > logger.Write (e.Message); > } > >} However, wrapping every single method like that is probably a really bad idea. What if the caller of the method expects the method to do something, what will happen when it either doesn't do anything, or maybe worse, does half of it. |
| | Re: Is try-catch block a way to prevent a crash? Hi Jack, I get the idea. I'll look at each method carefully to make sure they do what they're supposed to. I'll wrap the methods with a try-catch block to prevent any crash. |
| | Re: Is try-catch block a way to prevent a crash? On Jun 13, 8:32*am, Curious <fir5tsi...@xxxxxx> wrote: Quote: > Hi Jack, > > I get the idea. I'll look at each method carefully to make sure they > do what they're supposed to. > > I'll wrap the methods with a try-catch block to prevent any crash. http://msdn.microsoft.com/en-us/libr...exception.aspx Marc http://nomagichere.blogspot.com |
| | Re: Is try-catch block a way to prevent a crash? Curious <fir5tsight@xxxxxx> wrote: Quote: > I get the idea. I'll look at each method carefully to make sure they > do what they're supposed to. > > I'll wrap the methods with a try-catch block to prevent any crash. means it will fail fairly silently and keep going *in error conditions*. When an exception happens, most of the time the calling code won't be able to sensibly recover and complete the operation. For instance, if you're trying to return a web page and something goes wrong, your best course of action will be to display an error page - not plough on regardless of the error. Error handlers are usually at the top level of the application, or in *very* specific circumstances where you can actually work round the error (or retry, etc). Wrapping every method in try/catch is a recipe for disaster, as well as making your code much harder to understand. -- Jon Skeet - <skeet@xxxxxx> Web site: http://www.pobox.com/~skeet Blog: http://www.msmvps.com/jon.skeet C# in Depth: http://csharpindepth.com |
| | #6 (permalink) |
| | Re: Is try-catch block a way to prevent a crash? Curious wrote: Quote: > I get the idea. I'll look at each method carefully to make sure they > do what they're supposed to. > > I'll wrap the methods with a try-catch block to prevent any crash. example, when an exception occurs in BackgroundWorker(DoWork event) - it behaves as though happened nothing. So the application logic fails, without a visible hint. How to catch Exception in Background Worker http://devintelligence.com/blogs/net...7/17/1096.aspx Another hint: AppDomain.CurrentDomain.UnhandledException will not catch Exceptions in WPF applications. WPF requires a different way to catch unhandled exceptions, using app.DispatcherUnhandledException Maybe there are even more pitfalls in the Framework... Hope this Helps(tm) -- Michael Justin SCJP, SCJA betasoft - Software for Delphiâ„¢ and for the Javaâ„¢ platform http://www.mikejustin.com - http://www.betabeans.de |
| | #7 (permalink) |
| | Re: Is try-catch block a way to prevent a crash? After reading your posts, I feel it's very difficult to handle exceptions. Since my code is so complicated, I don't know what to do to handle so many possibilities of exceptions. I post a simple method here, could anyone kindly show me how to handle exception in this piece of code? void ReadBearTable() { try { StreamReader sr = new StreamReader(new FileStream("C:\ \Temp\\Bear.tkr", FileMode.Open, FileAccess.Read)); string line = sr.ReadLine(); while (line != null) { mBearList.Add(line); line = sr.ReadLine(); } sr.Close(); } catch (Exception e) { logger.LogMessageBarMessage(ESeverity.Error, e.Message); } } |
| | #8 (permalink) |
| | Re: Is try-catch block a way to prevent a crash? Ummmmm .... You've handled it! "Curious" <fir5tsight@xxxxxx> wrote in message news:041d714b-7a8e-47be-be64-32a5c1a926a2@xxxxxx Quote: > After reading your posts, I feel it's very difficult to handle > exceptions. Since my code is so complicated, I don't know what to do > to handle so many possibilities of exceptions. > > I post a simple method here, could anyone kindly show me how to handle > exception in this piece of code? > > void ReadBearTable() > { > try > { > StreamReader sr = new StreamReader(new FileStream("C:\ > \Temp\\Bear.tkr", FileMode.Open, FileAccess.Read)); > string line = sr.ReadLine(); > > while (line != null) > { > mBearList.Add(line); > > line = sr.ReadLine(); > } > > sr.Close(); > } > catch (Exception e) > { > logger.LogMessageBarMessage(ESeverity.Error, > e.Message); > } > } |
| | #9 (permalink) |
| | Re: Is try-catch block a way to prevent a crash? Curious <fir5tsight@xxxxxx> wrote: Quote: > After reading your posts, I feel it's very difficult to handle > exceptions. Since my code is so complicated, I don't know what to do > to handle so many possibilities of exceptions. continue? Quote: > I post a simple method here, could anyone kindly show me how to handle > exception in this piece of code? calls your ReadBearTable method won't know whether or not it's completed successfully? Or is it likely to be a critical error which really means your program can't continue? Should you let the caller decide instead of you just swallowing the exception? -- Jon Skeet - <skeet@xxxxxx> Web site: http://www.pobox.com/~skeet Blog: http://www.msmvps.com/jon.skeet C# in Depth: http://csharpindepth.com |
| What's wring with this try-catch block? | .NET General | |||
| Try Catch | .NET General | |||
| Catch-all | PowerShell | |||
| How to TRY and CATCH | PowerShell | |||
| I Catch VI | Vista hardware & devices | |||
