| | Problem Printing Objects From A Web Page I am pulling my hair out trying to print various objects from a .net web page My apologies for cross posting but I need an answer and my previous post has attracted no interest. ASP.Net 2.0 using C# This is a simple web page on our intranet (written as a test) and all I am trying to do is print a document to a named printer. If I use a StreamReader then I get an output to the printer. This prints all the lines in the text file to the printer. However, this only works for basic text files. I cannot achieve an output for an Excel spreadsheet, a MS Word document or a pdf document. If I choose not to use a StreamReader then all I get is a blank sheet of paper no matter what type of file I try to print. Can anyone please help as I am getting desperate as I need to create a complex web based printing application very soon. // A Simple HTML Page For A test web based application <body> <form runat="server"> <p> <ASP ropDownList id="ddlDebug"runat="server" AppendDataBoundItems="True" AutoPostBack="True"> <ASP:ListItem value="Debug">Stream </ASP:ListItem> <ASP:ListItem value="NoDebug">No Stream </ASP:ListItem> </ASP ropDownList></p> <p> <ASP:Button id="button2" runat="server" text="Button"> </ASP:Button> </p> <p> <ASP:ListBox id="listBox1" runat="server" width="1156px" height="442px"> </ASP:ListBox> </p></font> </form> </body> </html> // Some of the code behind if (! IsPostBack) { if(impersonateValidUser("Administrator", "domain", "password")) { //Insert your code that runs under the security context of a specific user here. } else { //Your impersonation failed. Therefore, include a fail-safe mechanism here. } } else { } } void myDoc_PrintPage(object sender, PrintPageEventArgs e) { float linesPerPage = 0; float yPos = 0; int count = 0; float leftMargin = e.MarginBounds.Left; float topMargin = e.MarginBounds.Top; topMargin = topMargin + 50; // When I try a direct print without Streaming I remove this block of code using (StreamReader streamToPrint = new StreamReader(myDoc.DocumentName)) { string Lline; // Read and display lines from the file until the end of the file is reached. while ((Lline = streamToPrint.ReadLine()) != null) { listBox1.Items.Add(Lline); // For debug purposes - DIsplay to browser listbox - Remove Later topMargin = topMargin + 20; yPos = topMargin + (count * printFont.GetHeight(e.Graphics)); e.Graphics.DrawString(Lline, printFont, Brushes.Black, leftMargin, yPos, new StringFormat()); } } // e.HasMorePages = true; } private void button2_Click(object sender, System.EventArgs e) { listBox1.Items.Clear(); // Try and print the document myDoc.DocumentName = @"\\MyPc\Temp\MyTestDoc.txt"; listBox1.Items.Add("Document Name - " + myDoc.DocumentName); myDoc.PrinterSettings.PrinterName = LPrinterName; listBox1.Items.Add("Printer Name - " + myDoc.PrinterSettings.PrinterName); foreach (System.Drawing.Printing.PaperSize paperSize in myDoc.PrinterSettings.PaperSizes) { if (paperSize.PaperName == "A3") { myDoc.DefaultPageSettings.PaperSize = paperSize; myDoc.DefaultPageSettings.PrinterSettings.DefaultPageSettings.Landscape = true; } } myDoc.PrinterSettings.FromPage = 1; myDoc.PrinterSettings.MinimumPage = 1; myDoc.PrintPage += new PrintPageEventHandler(myDoc_PrintPage); myDoc.Print(); } |
| Printing web page to a PDF | Vista print fax & scan | |||
| Printing Objects from a web page | .NET General | |||
| HP1020 not printing last page | Vista hardware & devices | |||
| printing test page | Vista print fax & scan | |||
| Printing q web page | Vista print fax & scan | |||
