Vista - Visual Studio 2003. NET Installation Issue
Old 06-17-2008   #1 (permalink)
watkinsdev
I currently have Visual Studio 6.0 Enterprise installed on my pc but I
would like to build a small web site using Visual Studio 2003 . NET.
Would there be a compatibility problem if I installed Visual Studio
2003. NET on the same pc or would the two applications run ok
independently from each other?
Old 06-17-2008   #2 (permalink)
Mr. Arnold
Re: Visual Studio 2003. NET Installation Issue
<watkinsdev@xxxxxx> wrote in message
news:7bea7a6f-2fd2-402f-97e2-160e07143afa@xxxxxx
I have seen machine with VS 2003 and 2005 or 2005 and 2008 on the same
machine being installed and used with no problems. So, no you're not going
to have an issue with VS 6.0.
Installation problem Visual Studio Vista installation & setup
How to Installing Visual Studio 2003 on Vista Home Basic Vista installation & setup
SP1 for Visual Studio 2003 wont install on RC1 Vista General
Installing Visual Studio .NET 2003 on Vista Build 5456 Vista General
Visual Studio 2005 installation failure Vista General
