Vista - Help with the collection contains method
Old 06-18-2008   #1 (permalink)
Tanzen
I'm working in visual studio 2005 trying to learn visual basic. Having
come from an VB for Access background, I'm finding it a big learning
curve. I have been working through several e-books which have shown
how to use custom collections to store lists of data. I've coded the
custom collection and before I add members to it, I want to use the
contains method to ensure the data does not already exist in the
collection. My play code is below.
Basically I have a form with a list box and a button. When you click
the button it is supposed to add a string value "Spot" to the dog
collection and then show that value in the list box. But it should
only add the item if the dog collection does not already contain
"Spot". I've highlighted the problem area below and all the project
code. The error I get when I try the code below is "Value of type
'String' can not be converted to 'basicCollections.Dog".
What I don't understand is why a string value would be unacceptable in
the contain method when the dog collection collects string data? Could
someone help explain what I am doing wrong?
Thank you,
'----------------------------- My Dog Collection Test
Public Class Form1
Private dog_list As New DogCollection
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e
As System.EventArgs) Handles Button1.Click
'<<<<<<<<<<<<<< ERROR >>>>>>>>>>>>>>>>>>
If Not dog_list.Contains("Spot") Then
' Value of type 'String' can not be converted to
'basicCollections.Dog'
dog_list.Add(New Dog("Spot"))
End If
For Each dog As Dog In dog_list
' Add Collection members to form list box
Me.ListBox1.Items.Add(dog.ToString)
Next dog
End Sub
End Class
Public Class Dog
Private m_Dog As String
Public Sub New(ByVal first_name As String)
m_Dog = first_name
End Sub
Public Overrides Function ToString() As String
Return m_Dog
End Function
End Class
' A strongly typed collection of Dogs.
Public Class DogCollection
Inherits CollectionBase
' Add an Dog.
Public Sub Add(ByVal value As Dog)
List.Add(value)
End Sub
' Return True if the collection contains this Dog.
Public Function Contains(ByVal value As Dog) As Boolean
Return List.Contains(value)
End Function
' Return this Dog's index.
Public Function IndexOf(ByVal value As Dog) As Integer
Return List.IndexOf(value)
End Function
' Return the Dog at this position.
Default Public ReadOnly Property Item(ByVal index As Integer) As
Dog
Get
Return DirectCast(List.Item(index), Dog)
End Get
End Property
End Class
Old 06-18-2008   #2 (permalink)
Morten Wennevik [C# MVP]
RE: Help with the collection contains method
Hi Tanzen,
The Contains method expects to be passed a Dog object. Either change the
line to
If Not dog_list.Contains(New Dog("Spot"))
or add a second Contains method that uses a string parameter
Public Function Contains(ByVal firstName As String) As Boolean
For Each dog As Dog In List
If dog.ToString() = firstName Then
Return True
End If
Next
Return False
End Function
Happy Coding!
> Thank you,
> Public Class Form1
> End If
> Next dog
> End Sub
> End Class
> Public Class Dog
> m_Dog = first_name
> End Sub
> Return m_Dog
> End Function
> End Class
> ' Add an Dog.
> List.Add(value)
> End Sub
> End Function
> End Function
> Dog
> Get
> End Get
> End Property
> End Class
Old 06-18-2008   #3 (permalink)
Jeff Gaines
Re: Help with the collection contains method
On 18/06/2008 in message
<D2B11613-DA99-4913-8C60-09D1EB575928@xxxxxx> Morten Wennevik [C#
MVP] wrote:
>line to
> Return True
> End If
> Next
> Return False
> End Function
Can I chime in with a question please?
If the dog_list already contains a Dog object where the name is Spot will
it be regarded as equal to a new Dog object where the name is also Spot?
It seems to me they are different objects.
I use your second technique in several of my apps which works fine for me.
Jeff Gaines Damerham Hampshire UK
The facts, although interesting, are irrelevant
Old 06-18-2008   #4 (permalink)
Hi Jeff,
The first method will consider two dogs to be different even if they are
called the same. The second method will consider two dogs to be the same if
they have the same name.
It is possible to get the first method to consider two dog objects to be
equal if they have the same name by overriding the Equals method in the dog
class. Remember to override GetHashCode as well if you override Equals. If
two objects are equal, they should generate the same hash code.
Happy Coding!
> MVP] wrote:
> >line to
> > Return True
> > End If
> > Next
> > Return False
> > End Function
Old 06-18-2008   #5 (permalink)
Jeff Gaines
<75C75A4E-23D1-4733-B9C5-74BA38829BC5@xxxxxx> Morten Wennevik [C#
>If
Will try that, thanks Morten :-)
I can please only one person per day. Today is not your day.
Tomorrow, isn't looking good either.
Old 06-18-2008   #6 (permalink)
Tanzen
You guys are fantastic. The first method provided by Morten did indeed
cause two separate "instances" with the name spot. So I used the
second method and it works perfectly. I would like to thank both you
gentlemen for the input as I was very much stuck.
If I may ask, would either of you have suggestions as to good resource
material to use on visual basic 2005/2008 .dotnet? I'm currently
subscribed to the Wrox training online library and reading everything
I can find on vb 2005. However, while they often give a cursory look
at the various methods capable in collections, hashtables and such,
they don't go into detail on each one. So while they may describe
working with add, remove, and so on, all I can find is usually a list
of other possible methods with only cursory recommendations on how
they might be used but without examples of their use to provide the
full syntax that is desperately needed for neophytes like me. Any
recommendations you may have on training material would be
appreciated.
I want to thank you again!
Aaron
Old 06-19-2008   #7 (permalink)
Jack Jackson
On Wed, 18 Jun 2008 19:32:16 -0700 (PDT), Tanzen
>appreciated.
>Aaron
I make heavy use of Google. You have to be careful because you will
find some obsolete and just plain wrong stuff, but you often can find
useful examples.
Old 06-19-2008   #8 (permalink)
Göran Andersson
Tanzen wrote:
8<
No, the collection doesn't contain string data, it contains instanced of
the Dog class.
In your Dog class you need a method that compares the dog to a string.
Then you can overload the Contains method in the collection with a
method that takes a string and loops through the list to check for a Dog
intance where the comparison method returns true.
Göran Andersson
_____
http://www.guffa.com
Civil War Collection Gaming
object not a collection VB Script
Method invocation failed because [System.String] doesn't contain a method PowerShell
Music Collection Vista music pictures video
Do You have any HDCD's in Your CD-collection? Vista mail
