Using Enterprise Library 4.0 Exception Handling Application Block
  1. #1
    Polly Anna Guest
    I have previously used EL v 3.1 Exception Handling application block
    successfully. I thought I would now try to do the same with EL v 4.0. My
    first experiment was to replace an exception.
    I created a project and added the following references -
    1/ Enterprise Library Exception Handling Application Block v 4.0
    (Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.dll)
    2/ Enterprise Library Shared v 4.0
    (Microsoft.Practices.EnterpriseLibrary.Common.dll)
    3/ Microsoft.Practices.ObjectBuilder v 1.0.51206.0 (then I tried version 2
    as well)(Microsoft.Practices.ObjectBuilder.dll)
    I then used the Configuration Manager to create the app.config file and add
    the
    Replace Handler to my new policy.
    I then added simple code in my application (see below) that uses the
    ExceptionPolicy.HandleException of EL.
    Unfortunately I get the error below and I can't figure out what is wrong.
    Please can someone point me in the right direction. I really would
    appreciate any help.
    Kind regards,
    Polly Anna
    Application Code -
    Dim i, j, k As Decimal
    Dim booRethrow As Boolean
    Try
    i = 1
    j = 0
    k = i / j
    Catch ex As Exception
    Try
    booRethrow = ExceptionPolicy.HandleException(ex, "Replace
    Policy")
    If booRethrow Then Throw
    txtMessage.Text = ex.ToString
    Catch ex2 As Exception
    txtMessage.Text = ex2.ToString
    End Try
    End Try
    End Sub
    Error Message -
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.ExceptionHandlingException:
    The current build operation (build key Build
    Key[Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.ExceptionPolicyImpl,
    Replace Policy]) failed: The type
    'Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.WCF.FaultContractWrapperException,
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.WCF, Version=4.0.0.0,
    Culture=neutral, PublicKeyToken=31bf3856ad364e35' cannot be resolved. Please
    verify the spelling is correct or that the full type name is provided.
    (Strategy type
    Microsoft.Practices.EnterpriseLibrary.Common.Configuration.ObjectBuilder.ConfiguredObjectStrategy,
    index 2) ---> Microsoft.Practices.ObjectBuilder2.BuildFailedException: The
    (Strategy type
    index 2) ---> System.ArgumentException: The type
    at
    Microsoft.Practices.EnterpriseLibrary.Common.Configuration.AssemblyQualifiedTypeNameConverter.ConvertFrom(ITypeDescriptorContext
    context, CultureInfo culture, Object value)
    at System.ComponentModel.TypeConverter.ConvertFrom(Object value)
    at
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.Configuration.ReplaceHandlerData.get_ReplaceExceptionType()
    at
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.Configuration.ReplaceHandlerAssembler.Assemble(IBuilderContext
    context, ExceptionHandlerData objectConfiguration, IConfigurationSource
    configurationSource, ConfigurationReflectionCache reflectionCache)
    at
    Microsoft.Practices.EnterpriseLibrary.Common.Configuration.ObjectBuilder.AssemblerBasedObjectFactory`2.Create(IBuilderContext
    context, TConfiguration objectConfiguration, IConfigurationSource
    at
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.ExceptionPolicyEntryCustomFactory.Create(IBuilderContext
    context, ExceptionTypeData objectConfiguration, IConfigurationSource
    at
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.ExceptionPolicyCustomFactory.CreateObject(IBuilderContext
    context, String name, IConfigurationSource configurationSource,
    at
    Microsoft.Practices.EnterpriseLibrary.Common.Configuration.ObjectBuilder.ConfiguredObjectStrategy.PreBuildUp(IBuilderContext context)
    at
    Microsoft.Practices.ObjectBuilder2.StrategyChain.ExecuteBuildUp(IBuilderContext context)
    --- End of inner exception stack trace ---
    at
    at Microsoft.Practices.ObjectBuilder2.Builder.BuildUp(IReadWriteLocator
    locator, ILifetimeContainer lifetime, IPolicyList policies, IStrategyChain
    strategies, Object buildKey, Object existing)
    at
    Microsoft.Practices.ObjectBuilder2.Builder.BuildUp[TTypeToBuild](IReadWriteLocator
    at
    Microsoft.Practices.EnterpriseLibrary.Common.Configuration.ObjectBuilder.EnterpriseLibraryFactory.BuildUp[T](IReadWriteLocator
    locator, ILifetimeContainer lifetimeContainer, String id,
    IConfigurationSource configurationSource)
    at
    Microsoft.Practices.EnterpriseLibrary.Common.Configuration.ObjectBuilder.LocatorNameTypeFactoryBase`1.Create(String name)
    at
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.ExceptionPolicy.GetExceptionPolicy(Exception
    exception, String policyName, ExceptionPolicyFactory factory)
    at
    at
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.ExceptionPolicy.HandleException(Exception
    exceptionToHandle, String policyName, ExceptionPolicyFactory policyFactory)
    at
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.ExceptionPolicy.HandleException(Exception exceptionToHandle, String policyName)
    at EHAB4v.Form1.cmdReplace_Click(Object sender, EventArgs e) in
    C:\Documents and Settings\David Woodhouse\My Documents\Visual Studio
    2008\Projects\EHAB4v\EHAB4v\Form1.vb:line 21
  2. #2
    Jeff Winn Guest
    Re: Using Enterprise Library 4.0 Exception Handling Application Block
    Should have read the exception message closer - it tells you exactly what
    the issue is.
    Version=4.0.0.0,
    It can't locate an assembly with that assembly name with the types specified
    in your app.config file. Typically with the exception handling block in Ent
    Lib people reference the correct assemblys in order to implement it in their
    applications but forget to deploy the other assemblies that it needs with
    it. Since your application isn't referencing the
    Microsoft.Practices.EnterpriseLibrary.ExceptionHandling.WCF.dll directly
    when it's trying to log the exception it can't find the assembly inside the
    bin folder you told it to use in your config file.
    "Polly Anna" <Polly Anna@xxxxxx> wrote in message
    news:567E7B3F-BBCB-4A82-8DDC-EBA5F65B4CFB@xxxxxx
    > Hi,
    > My
    > 2
    > add
    > the
    > Kind regards,
    > Polly Anna
    > Application Code -
    > Try
    > i = 1
    > j = 0
    > k = i / j
    > Try
    > Policy")
    > End Try
    > End Try
    > End Sub
    > Error Message -
    > Version=4.0.0.0,
    > Please
    > (Strategy type
    > Version=4.0.0.0,
    > Please
    > (Strategy type
    > Version=4.0.0.0,
    > Please
    > at
    > at
    > at
    > at
    > at
    > at
    > at
    > context)
    > at
    > context)
    > at
    > context)
    > at
    > at
    > at
    > name)
    > at
    > at
    > at
    > policyFactory)
    > at
Structured Exception Handling Overwrite Protection Axon Vista News 1 10 Sep 2008
Exception Handling Application Block Polly Anna .NET General 2 17 May 2008
Getting Custom Source Name Using Enterprise Library Logging Block Shrikant More .NET General 0 02 Apr 2008
Custom Exception Handling And Logging using EnterPrise Library app Shrikant More .NET General 0 31 Mar 2008
Exception handling in Vista Application Aale de Winkel Vista General 0 16 Apr 2007
