Vista - MSBuild script for Getlatest cource code
Old 06-25-2008   #1 (permalink)
Abhi
Both Team Build and CruiseControl.NET use MSBuild when they're building the
solution. They just handle source code retrieval, building, logging and a lot
of other things you're going to need if you're trying to automate the build
process.
Team Build comes with the ability to connect to TFS servers out of the box
naturally, while CruiseControl (which is what we use currently until we
upgrade to TFS 2008) just needs an extra free DLL that it uses to connect to
TFS when it starts the build process.
Writing your own MSBuild script isn't the answer you should be looking for.
Research using Team Build or CruiseControl if you're trying to automate your
build process. Depending on which version of TFS you're using, you may need
to download some additional components if you're trying to use a continuous
integration build process. CC.NET comes with this ability out of the box.
"Abhi" wrote:
Quote:
> But i want to use MSBUILD script because i will be using it for creating
> Build also.
> please help me in this direction.
> Thanks
> Abhi
> "jwinn" wrote:
Quote:
> > Why not just use Team Build? If Team Build isn't an option, look into using
> > CruiseControl.NET.
> > "Abhi" wrote:
Quote:
> > > Hi All,
> > > I need to write MSBuild script to get latest source code of
> > > solution/Projects from TFS server.I m using VS2008.
> > > I am new to this, can anyone plz help me how can i do this.
> > > Thanks
> > > Abhi
Old 06-25-2008   #2 (permalink)
jwinn
RE: MSBuild script for Getlatest cource code
CruiseControl.NET.
"Abhi" wrote:
Quote:
> Hi All,
> Thanks
> Abhi
Old 06-26-2008   #3 (permalink)
Abhi
Build also.
Thanks
Abhi
"jwinn" wrote:
> CruiseControl.NET.
> "Abhi" wrote:
Quote:
> > Hi All,
> > Thanks
> > Abhi
Old 06-26-2008   #4 (permalink)
Jeff Winn
process.
"Abhi" wrote:
> Build also.
> Thanks
> Abhi
> "jwinn" wrote:
> > CruiseControl.NET.
> > "Abhi" wrote:
Quote:
> > > Hi All,
> > > Thanks
> > > Abhi
Script-based code sample library (HTA) VB Script
VB script just keeps looping and does not excute the code VB Script
Auto-filling VB Script Code for Excel VB Script
Is there a shorter code to perform this ps1 script ? PowerShell
Generating documentation for script code (MAML?) PowerShell
