Vista - Target operating system
Old 06-30-2008   #1 (permalink)
PawelSokolowski
Hi all,
After changing VS2003 to VS2008 my C++ app stopped working on Windows NT 4.0
It says, that this is not valid application or something like this.
Is there any settings concerning target platform, not only x86 ?
Regards
Pawel
Old 06-30-2008   #2 (permalink)
Jeroen Mostert
Re: Target operating system
VS2008 no longer supports Windows NT as a target platform
(http://msdn.microsoft.com/library/bb531344), so this is not completely
unexpected.
A forum thread discussing this in more detail is here:
http://www.msfn.org/board/lofiversio...p/t112283.html
It links to a more complete discussion here:
http://groups.google.com/group/Visua...74dafe3eb6ef5/
This discusses some tweaks for getting it to work, but your best bet is
really to stick with the last version of VS that still fully supports NT
4.0. If I'm not mistaken, VS2005 should still produce executables that run
on NT 4.0.
Lots, among them alignment, runtime library to link, processor architecture,
manifest file and probably one or two others I'm forgetting. Your main
hurdle will be that as Windows moves forward, the runtime libraries will
start linking with functions they'll assume to be present (and are not on NT
4.0) and not using the runtime libraries isn't really an option.
Try getting a "hello, world!" application working before your try anything
more complicated.
J.
Old 06-30-2008   #3 (permalink)
Phil Wilson
You'll need to install the VS 2008 C++ run time support on whatever
supported OS you want to run on. e.g.
http://www.microsoft.com/downloads/d...displaylang=en
Phil Wilson
Definitive Guide to Windows Installer
http://www.apress.com/book/view/1590592972
"PawelSokolowski" <PeeS290@xxxxxx> wrote in message
news:%23nkkywq2IHA.4920@xxxxxx
Quote:
> Hi all,
> 4.0
> Regards
> Pawel
Cannot Find Operating System! Help! General Discussion
Operating System Virtual PC
When the operating system Vista General
operating system Vista installation & setup
Operating System Help Vista General
