| | Convert Formatted Double Into String I have a double stored in a DataTable: dt.Rows(i)(MergeFieldName) I want to format this and store it into a string. I have formatting stored in a database, such as "$#,##0.00" How do I use this formatting, apply it to dt.Rows(i)(MergeFieldName), which is a double, and then store it in a string? So if the value of dt.Rows(i)(MergeFieldName) is 14,122.05. I would get $14,122.05. Derek |
| | Re: Convert Formatted Double Into String "Derek Hart" <derekmhart@xxxxxx> schrieb Quote: > I have a double stored in a DataTable: dt.Rows(i)(MergeFieldName) > > > > I want to format this and store it into a string. > > > > I have formatting stored in a database, such as "$#,##0.00" > > > > How do I use this formatting, apply it to > dt.Rows(i)(MergeFieldName), which is a double, and then store it in > a string? > > > > So if the value of dt.Rows(i)(MergeFieldName) is 14,122.05. I would > get $14,122.05. What's the format of the format? I guess it's one of these:http://msdn.microsoft.com/en-us/library/427bttx3.aspx Example: dim fmt as string = "$#,##0.00" dim s as string s = directcast(dt.Rows(i)(MergeFieldName), double).ToString(fmt) Armin |
| | Re: Convert Formatted Double Into String As long as the type you're trying to format is a numeric data type the formatting will work just fine. However, if you're trying to take a string type that contains numeric data you will need to parse it to the appropriate type before you can format it. Example A: Dim s As String = "1234.44" s.ToString("$#,##0.00") Will not work. Example B: Dim d As Double = Double.Parse("1234.44") d.ToString("$#,##0.00") Will work properly. "Armin Zingler" wrote: Quote: > "Derek Hart" <derekmhart@xxxxxx> schrieb Quote: > > I have a double stored in a DataTable: dt.Rows(i)(MergeFieldName) > > > > > > > > I want to format this and store it into a string. > > > > > > > > I have formatting stored in a database, such as "$#,##0.00" > > > > > > > > How do I use this formatting, apply it to > > dt.Rows(i)(MergeFieldName), which is a double, and then store it in > > a string? > > > > > > > > So if the value of dt.Rows(i)(MergeFieldName) is 14,122.05. I would > > get $14,122.05. > > What's the format of the format? I guess it's one of these:> http://msdn.microsoft.com/en-us/library/427bttx3.aspx > > Example: > dim fmt as string = "$#,##0.00" > dim s as string > > s = directcast(dt.Rows(i)(MergeFieldName), double).ToString(fmt) > > > Armin > > |
| Convert Byte() to string | VB Script | |||
| Convert to & from base64 String | PowerShell | |||
| convert int to numeric (formatted) string | .NET General | |||
| convert array of strings to string | PowerShell | |||
| here-string with single and double quotes | PowerShell | |||
