Vista - RE: invisible classes outside the Class Library
Old 07-07-2008   #1 (permalink)
Jeff Winn
Just change the access modifier on the classes you don't want exposed to
internal instead of public.
public class MyClass {
Would become:
internal class MyClass {
If you're using VB, it'd be Friend instead of internal.
"buu" wrote:
Quote:
> So, I have my class library that contains multiple classes, but I would like
> to have only one of them to be visible outside the library...
> how?
Icons in dll / assembly / class library .NET General
Adding class library to website .NET General
Re: invisible classes outside the Class Library .NET General
Using a C# Class Library with VB6 .NET General
How do I check if class library is being used by web or windows ap .NET General
