| | Read registry using vb/java scripts Hi I am a newbie to ASP.NET and VBScript, currently I am designing a page to show all the mapped drives using client-side scripts.. I want to read all the mapped drive details (name and Remote Path) from the registry ("JKEY_CURRENT_USER\Network\") then I want to show this in list box like P: \\machine1\folder1 Z: \\mahcine2\folder2 How to read all the keys (i.e.: drive names D,E,F...Z) under "HKCU \Network" and "RemotePath" key under each drive names using script (VB or JAVA) ? Also tell me how to use this script in the ASP.NET page or Class file to fill the list box control Its bit urgent.. Thanks in advance Msk. |
| | Read registry using vb/java scripts Hi I am a newbie to ASP.NET and VBScript, currently I am designing a page to show all the mapped drives using client-side scripts.. I want to read all the mapped drive details (name and Remote Path) from the registry ("HKEY_CURRENT_USER\Network\") then I want to show this in a list box like P: \\machine1\folder1 Z: \\mahcine2\folder2 How to read all the keys (i.e.: drive names D,E,F...Z) under "HKCU \Network" and "RemotePath" key under each drive names using script (VB or JAVA) ? Also tell me how to use this script in the ASP.NET page or Class file to fill the list box control Its bit urgent.. Thanks in advance Msk. |
| | Re: Read registry using vb/java scripts MSK wrote: Quote: > I am a newbie to ASP.NET and VBScript, currently I am designing a page > to show all the mapped drives using client-side scripts.. > I want to read all the mapped drive details (name and Remote Path) > from the registry ("JKEY_CURRENT_USER\Network\") then I want to show > this in list box like > > P: \\machine1\folder1 > Z: \\mahcine2\folder2 > > How to read all the keys (i.e.: drive names D,E,F...Z) under "HKCU > \Network" and "RemotePath" key under each drive names using script > (VB or JAVA) ? > to the list of mapped drives), for obvious security reasons. There are multiple approaches you can look into: - You can use server-side WMI (see, for example, http://www.microsoft.com/technet/scr...5/hey1027.mspx). This requires that the web server (and the account the page is running under) have remote access to the client computer's WMI interfaces. - You can write an ActiveX component in .NET for accessing the list of network drives (using WMI, for example) and deploy it in your website. This requires the use of IE and may need lowered security. - You can deploy client-side scripts for WMI, which can post the information to a website (or do anything else with it). These have to be run outside the web browser, but they can be downloaded from the web browser. Again, this may need security adjustments. - You can deploy the application as fully client-side, for example through ClickOnce. Note that in most cases, you should prefer WMI to direct registry access, as it saves you the trouble of interpreting information in the registry yourself (which is error-prone and subject to breaking on changes). WMI has a rich object model that exposes just about anything you could be interested in. -- J. |
| | Re: Read registry using vb/java scripts Thanks for immediate answers... MSK |
| | Re: Read registry using vb/java scripts Please do not MULTI POST. http://groups.google.com/group/micro...3e3fc09a764e9# "MSK" <kartechy@xxxxxx> wrote in message news:3e14a927-d480-49c1-81a3-85c4d285372a@xxxxxx Quote: > Hi > > I am a newbie to ASP.NET and VBScript, currently I am designing a page > to show all the mapped drives using client-side scripts.. > I want to read all the mapped drive details (name and Remote Path) > from the registry ("JKEY_CURRENT_USER\Network\") then I want to show > this in list box like > > P: \\machine1\folder1 > Z: \\mahcine2\folder2 > > How to read all the keys (i.e.: drive names D,E,F...Z) under "HKCU > \Network" and "RemotePath" key under each drive names using script > (VB or JAVA) ? > > Also tell me how to use this script in the ASP.NET page or Class file > to fill the list box control > > Its bit urgent.. > > Thanks in advance > Msk. |
| unable to add java scripts | General Discussion | |||
| Script: read a registry key | VB Script | |||
| Re: Printer cannot read registry key? | Vista print fax & scan | |||
| Read from Registry on Vista | Vista security | |||
| Read from Registry on Vista | Vista General | |||
