| | counting problem "kEV" <kEV@xxxxxx> wrote in message news:7C3E9641-61B7-40AB-9CAA-8DD315804CF4@xxxxxx Quote: > Hi, > > I'm trying to count the number of instances a "house" for example in B1 > falls within a "rent" value of between >20 and <32 in D1 > and need to change instances to "flat" and ranges, please see example > below > Type RENT > House 58.98 > Flat 31.50 > Flat 36.50 > > answer would be count of 1 (flat with rent greater than 20 and less than > 32 > i'm trying to use > Sumproduct(--(B1:B500="house"),--(D1 500="<32")),--(D1 500=">20"))> just > by reading other peop[les posts but am unable to get it to work despite > changing the formula slightly > > can anyone please help, greatly appreciated > thankyou in advance What product are you using? Excel by chance? If so, you need to find a group for the software you are using. Here's how to get there via the web interface: http://www.microsoft.com/communities...s/default.aspx Click the + beside your language. then scroll down to Office and Desktop Applications. In Office and Desktop Applications, find the category for the software you are using. Open it and find a group for your software to your question. |
| | Re: counting problem "kEV" <kEV@xxxxxx> wrote in message news:7C3E9641-61B7-40AB-9CAA-8DD315804CF4@xxxxxx Quote: > Hi, > > I'm trying to count the number of instances a "house" for example in B1 > falls within a "rent" value of between >20 and <32 in D1 > and need to change instances to "flat" and ranges, please see example > below > Type RENT > House 58.98 > Flat 31.50 > Flat 36.50 > > answer would be count of 1 (flat with rent greater than 20 and less than > 32 > i'm trying to use > Sumproduct(--(B1:B500="house"),--(D1 500="<32")),--(D1 500=">20"))> just > by reading other peop[les posts but am unable to get it to work despite > changing the formula slightly > > can anyone please help, greatly appreciated > thankyou in advance What product are you using? Excel by chance? If so, you need to find a group for the software you are using. Here's how to get there via the web interface: http://www.microsoft.com/communities...s/default.aspx Click the + beside your language. then scroll down to Office and Desktop Applications. In Office and Desktop Applications, find the category for the software you are using. Open it and find a group for your software to your question. |
| counting file name | Vista file management | |||
| Re: 1 3/4 hour and counting | Vista General | |||
| RC-1 install - 6 hrs and counting | Vista installation & setup | |||
