Vista - "Visual Web Developer" questions
Old 07-18-2008   #1 (permalink)
Kelvin
Thanks, I'll do that...
"PvdG42" <pvdg@xxxxxx> wrote in message
news:uAp10dO6IHA.1204@xxxxxx
Quote:
> "Kelvin" <someone@xxxxxx> wrote in message
> news:edPBmLO6IHA.1192@xxxxxx
Quote:
>> I've installed Microsoft Visual Web Developer 2008 Express Edition and
>> have a couple questions.
>> At the time I did the install, I had my My Documents folder mapped to a
>> network drive.
>> I have since mapped it back to my local drive, how can I get VWD to
>> recognize the new path?
>> I have also installed DotNetNuke and when I go to setup the database it
>> comes back with an error that indicates that it can't create the DB on a
>> mapped drive...
>> If it's just the DotNetNuke project that is recognizing the network path
>> to my My documents, how do I delete a project?
>> I ended up creating more than one DotNetNuke project so would like to
>> delete the extra one.
>> I can't see any way to delete a project...
>> Any help would be appreciated!!!
>> If this isn't the place to post these questions, please advise on the
>> appropriate group.
>> I've running this on an XP Pro machine if it matters.
>> Thanks!
>> Kelvin
> Perhaps the simplest way to solve your issues would be to uninstall, then
> reinstall VWD.
> As far as deleting projects is concerned, find the folder using Windows
> Explorer and delete it.
Old 07-18-2008   #2 (permalink)
PvdG42
Re: "Visual Web Developer" questions
> network drive.
> mapped drive...
> appropriate group.
> Thanks!
> Kelvin
reinstall VWD.
Old 07-18-2008   #3 (permalink)
Kelvin
>> network drive.
>> mapped drive...
>> appropriate group.
>> Thanks!
>> Kelvin
> reinstall VWD.
custom shortcut for "adjust visual effect" Vista performance & maintenance
Vista not wotking with "My Computer" or "Control Panel", "Screen Saver" Vista General
Keep getting error: "Microsoft visual basic c++ runtime library" Vista General
"Disable Visual Themes" option doesn't work in app properties. Vista General
"Open with" fails with Visual Studio 2005 Vista file management
