Vista - When using System.IO.FileStream, I write 8 bytes, then seek to the start of the file, does the 8 bytes get flushed on seek and the buffer become a readbuffer at that point instead of being a write buffer?
Old 07-28-2008   #1 (permalink)
DR
Old 07-29-2008   #2 (permalink)
Anthony Jones
Re: When using System.IO.FileStream, I write 8 bytes, then seek to the start of the file, does the 8 bytes get flushed on seek and the buffer become a readbuffer at that point instead of being a write buffer?
"DR" <softwareengineer98037@xxxxxx> wrote in message
news:OZoyDzR8IHA.1200@xxxxxx
of
A simple experiment in .NET 2.0 and Windows XP shows that it does appear to
flush on the seek.
However whether you should rely in that behaviour depends on why you asked
the question. If you are worried that you might be overwritting data that
hasn't been stored yet then don't be.
If you want to make sure that data is persisted before doing other things
then you should explicitly flush. Just because seek appears to flush in a
the above case may simply be a result of specific OS decisions. In other
circumstances the underlying OS (on windows FileStream is a fairly
transparent wrapper on the Win APIs for these operations) may make other
choices.
Anthony Jones - MVP ASP/ASP.NET
how to get powershell to write to event log or write a log file? PowerShell
Hide N' Go Seek HDD Vista hardware & devices
Please advise where to seek help? Vista General
Slow File transfer - 0 bytes/sec General Discussion
Windows Explorer: Display File Size Column In Bytes? Vista file management
