| | slow copy speed so when i try to copy/cut a file to place in another detination, i get a max speed of 10.2 Mps.... this is very daunting, as i have to move about 26 gigs of information off of my slave drive to re-format it... at that rate it will take over seven hours for it to comple, providing it stays at max speed... but i don't have the time to do that, nor do i want to bog down my CPU with it either.... so, is there a way to increase my file transfer rate? |
| | Re: slow copy speed "firstmateirongut" <firstmateirongut@xxxxxx> wrote in message news:0068E992-ADAC-4452-A227-D6A72DBEE670@xxxxxx Quote: > so when i try to copy/cut a file to place in another detination, i get a > max > speed of 10.2 Mps.... this is very daunting, as i have to move about 26 > gigs > of information off of my slave drive to re-format it... at that rate it > will > take over seven hours for it to comple, providing it stays at max speed... > but i don't have the time to do that, nor do i want to bog down my CPU > with > it either.... so, is there a way to increase my file transfer rate? or using Windows utilities directly? If the latter, you need to find an appropriate Windows group to ask in. Here's how. As you appear to be using a web interface, start here to find an appropriate group: http://www.microsoft.com/communities...s/default.aspx Click the + beside your language. then scroll down to Windows. In Windows, open the category for your version of Windows, then find a group there to post in. |
| | Re: slow copy speed ***Are you trying to do this from within a .NET application you're developing, Quote: > or using Windows utilities directly?*** drive to my c:\ drive.... lol "PvdG42" wrote: Quote: > > "firstmateirongut" <firstmateirongut@xxxxxx> wrote in > message news:0068E992-ADAC-4452-A227-D6A72DBEE670@xxxxxx Quote: > > so when i try to copy/cut a file to place in another detination, i get a > > max > > speed of 10.2 Mps.... this is very daunting, as i have to move about 26 > > gigs > > of information off of my slave drive to re-format it... at that rate it > > will > > take over seven hours for it to comple, providing it stays at max speed... > > but i don't have the time to do that, nor do i want to bog down my CPU > > with > > it either.... so, is there a way to increase my file transfer rate? > Are you trying to do this from within a .NET application you're developing, > or using Windows utilities directly? If the latter, you need to find an > appropriate Windows group to ask in. Here's how. > > As you appear to be using a web interface, start here to find an appropriate > group: > > http://www.microsoft.com/communities...s/default.aspx > > Click the + beside your language. then scroll down to Windows. In Windows, > open the category for your version of Windows, then find a group there to > post in. > > > > > |
| copy speed | General Discussion | |||
| Data transfer copy speed | General Discussion | |||
| Slow file copy in Vista (VERY VERY slow in fact) | Vista General | |||
| Increasing file copy speed | Vista performance & maintenance | |||
| Speed very slow | Vista General | |||
