| | How can I manage/encapsulate failures of an Active X control I have an Active-X control provided by a vendor that will inadvertenly crash while processing. The good part is that I do have a way to save information routinely as it is processing in the event it crashes. From there I can start over and I can eventually finish the process. My problem is that at this stage I have been doing this manually, but now I have to come up with an automated solution. What I want is to have my program run, save the data at increments and restart when the Active- X control crashed without the user ever knowing it. My mayor concern which is also the main question. Is how to do it the best way, and if there is a possibility for memory leaks.? The problem with a memory leak is that eventually the spawning process may not work and it would default to the original behaviour of crashing in the middle of the process. I would normally want to call the process using a regular procedure call instead of a command line call. But it may be that the command line islates the processes better. I am asigning "Nothing" to the Active-X object at the end of the run, and I also have a try block to make sure the asignment runs. Thanks in advance for any help. Arturo Hernandez |
| Re: Service Pack 1 and Control Panel Applet Failures | Vista performance & maintenance | |||
| Re: Service Pack 1 and Control Panel Applet Failures | Vista General | |||
| Active X control | Vista installation & setup | |||
| Active X control | Vista security | |||
