| | Re: P/Invoke Problem selected index changing >''try to set focus Quote: >SendNotifyMessage(ipCountry, WM_SETFOCUS, IntPtr.Zero, IntPtr.Zero) > >SendMessageByString(ipCountry, CB_SETCURSEL, iCountryCbo, 0) > >SendNotifyMessage(ipZip, WM_SETFOCUS, IntPtr.Zero, IntPtr.Zero) > >I tried moving the setfocus calls around with no luck- Have you also tried sending WM_KILLFOCUS to the window that you "tab out from"? Mattias -- Mattias Sjögren [C# MVP] mattias @ mvps.org http://www.msjogren.net/dotnet/ | http://www.dotnetinterop.com Please reply only to the newsgroup. |
| How how do you index files with changing extentions | General Discussion | |||
| Score Index Downgrade without changing hardware | Vista General | |||
| invoke-expression problem | PowerShell | |||
| problem with invoke-expression | PowerShell | |||
| WLMD Beta problem: cannot move selected messages | Vista mail | |||
