| | Which data control gives me this view? I want to get a logged in user's properties into a vertical template ============================================= FieldName Label | FieldValueToEdit Label ============================================= LinkedFieldToEdit | ValueToEdit .... | ... .... | ... ============================================= Which data control in the framework should be used and if more than one choice is available using templates a quick comment on why please... |
| | RE: Which data control gives me this view? Hi Billy, Would you be looking for a PropertyGrid? This is what is used for editing properties in the Visual Studio IDE and supports various ways of editing the values, including custom ones. There are many examples on how to use a PropertyGrid http://www.c-sharpcorner.com/UploadF...dInCSharp.aspx A more indept example showing how to use custom types in the grid: http://msdn.microsoft.com/en-us/library/aa302326.aspx -- Happy Coding! Morten Wennevik [C# MVP] "HillBilly" wrote: Quote: > I want to get a logged in user's properties into a vertical template > > ============================================= > FieldName Label | FieldValueToEdit Label > ============================================= > LinkedFieldToEdit | ValueToEdit > .... | ... > .... | ... > ============================================= > > Which data control in the framework should be used and if more than one > choice is available using templates a quick comment on why please... > > |
| | Re: Which data control gives me this view? Hello there Morten, yes web developers need a PropertyGrid as it looks exactly what I would like to use. I started by reviewing the QuickStarts [1] where I'm sure one of the data controls may be used but its not easy to determine which one supports vertical orientation. Perhaps somebody will comment further... [1] http://quickstarts.asp.net/QuickStar...a/default.aspx "Morten Wennevik [C# MVP]" <MortenWennevik@xxxxxx> wrote in message news:BED7A6CE-8C46-451A-96CD-7A9283B6EC48@xxxxxx Quote: > Hi Billy, > > Would you be looking for a PropertyGrid? This is what is used for editing > properties in the Visual Studio IDE and supports various ways of editing > the > values, including custom ones. > > There are many examples on how to use a PropertyGrid > > http://www.c-sharpcorner.com/UploadF...dInCSharp.aspx > > A more indept example showing how to use custom types in the grid: > > http://msdn.microsoft.com/en-us/library/aa302326.aspx > > -- > Happy Coding! > Morten Wennevik [C# MVP] > > > "HillBilly" wrote: > Quote: >> I want to get a logged in user's properties into a vertical template >> >> ============================================= >> FieldName Label | FieldValueToEdit Label >> ============================================= >> LinkedFieldToEdit | ValueToEdit >> .... | ... >> .... | ... >> ============================================= >> >> Which data control in the framework should be used and if more than one >> choice is available using templates a quick comment on why please... >> >> |
| HTA RDS Data Control problem | VB Script | |||
| KHz sample rate data and other key data fields missing from audio/media file properties view | Vista file management | |||
| Classic View Control Panel Won't Stay as Default View | Vista General | |||
| Parental Control - Can't view log | Vista General | |||
| Control Panel Category View gone... | Vista performance & maintenance | |||
