| | DataGridView firing way to many SelectionChangedEvents! Please Help Hi all, I'm really hoping someone can help me with this as it's causing me some serious problems. I have a Windows Forms application using the gridview control. When the user selects a row, the SelectionChanged event fires and I load some more data that's particular to that row. The problem I'm having is that the SelectionChanged event is going way to many times and this is obviously causing me to load the additional data scores of times when it's not necessary. The sorts of things that are causing it to occur are:- - Refreshing the data - Calling ClearSelection - Calling Sort I can certainly understand why these actions would cause the SelectionChanged event to fire, but the problem is the sheer number of times it fires. For example for some reason, when I refresh the binding source's data, it will fire say, 5 times. Then if I do it again, it will become 10 times even though I'm clearing the data and not adding to it. Similarly, when I call sort it seems to cause SelectionChanged to fire once for each row. I've tried all sorts of things like detaching event handlers and then reattaching them after performing a key action but this only helps a little. Sometimes detaching the event handler doesn't seem to do anything - the event still fires! Can anyone help me with some strategy for dealing with this. I'd be really surprised if I were the only person that was experiencing this so I'm hoping someone will be able to help me. Sincerest thanks to anyone who can advise Best Regards Simon |
| | Re: DataGridView firing way to many SelectionChangedEvents! Please Help :-( On Sun, 10 Aug 2008 20:41:23 +0100, Simon Harvey <nothanks@xxxxxx> wrote: Quote: >Hi all, > >I'm really hoping someone can help me with this as it's causing me some >serious problems. > >I have a Windows Forms application using the gridview control. When the >user selects a row, the SelectionChanged event fires and I load some >more data that's particular to that row. > >The problem I'm having is that the SelectionChanged event is going way >to many times and this is obviously causing me to load the additional >data scores of times when it's not necessary. > >The sorts of things that are causing it to occur are:- >- Refreshing the data >- Calling ClearSelection >- Calling Sort > >I can certainly understand why these actions would cause the >SelectionChanged event to fire, but the problem is the sheer number of >times it fires. For example for some reason, when I refresh the binding >source's data, it will fire say, 5 times. Then if I do it again, it will >become 10 times even though I'm clearing the data and not adding to it. >Similarly, when I call sort it seems to cause SelectionChanged to fire >once for each row. > >I've tried all sorts of things like detaching event handlers and then >reattaching them after performing a key action but this only helps a >little. Sometimes detaching the event handler doesn't seem to do >anything - the event still fires! > >Can anyone help me with some strategy for dealing with this. I'd be >really surprised if I were the only person that was experiencing this so >I'm hoping someone will be able to help me. > >Sincerest thanks to anyone who can advise > >Best Regards > >Simon solution to this. Some things I have done to mitigate this are: Use a subclassed DataGridView. Override the Sort and OnCellClick methods to determine when the grid is sorting, and in OnSelectionChanged don't call the base class method to prevent the SelectionChanged event from occurring. Clear DataSource before making changes and restoring it afterwards. Subclass the DataGridView and put code in OnSelectionChanged to try to notice redundant calls. Subclass the DataGridView and add a method to set/reset a flag. Call it to disable the events before making changes and call it to enable after. Override OnSelectionChanged and if the disable flag is set don't call the base class OnSelectionChanged. If the event handler is detached, it is not possible for the event handler to be called. My guess is either you don't have the detach and attach paired so that you have it attached more than once, or the grid is raising the event after you reattach. If you put a breakpoint on the handler and look at call stack window you should be able to tell what raised the event. Events occurring later than you expect is a big problem when the grid is first being instantiated - many grid events are delayed until the grid becomes visible. |
| | Re: DataGridView firing way to many SelectionChangedEvents! Please Hi Jack, Thank you ver much for your reply. I have been trying various incarantions of these suggestions though I haven't gone as far as trying to subclass the control. Quick question. When you say: Quote: > "Clear DataSource before making changes and restoring it afterwards." assign it to my BindingSource's DataSource property. e.g. tblPlaces = tableAdapter.SelectAll(); bsPlacesBindingSource.DataSource = tblPlaces; This works but each time the number of SelectionChanged events that are fired increases, which I don't understand. It's almost as though behind the scenes the number of rows is quietly increasing each time, but that doesn't appear to be the case because the grid continues to display the correct number of rows (eventually!) I'm wondering from your reply if there is a better way to refresh the data that my bindingsourece or datagridview is using? Many thanks again for your help Simon |
| | Re: DataGridView firing way to many SelectionChangedEvents! Please Help :-( On Mon, 11 Aug 2008 11:35:09 +0100, Simon <nothanks@xxxxxx> wrote: Quote: >Hi Jack, > >Thank you ver much for your reply. I have been trying various >incarantions of these suggestions though I haven't gone as far as trying >to subclass the control. > >Quick question. When you say: > Quote: >> "Clear DataSource before making changes and restoring it afterwards." >How do I do this exactly? At the moment I just get my datatable and then > assign it to my BindingSource's DataSource property. e.g. > >tblPlaces = tableAdapter.SelectAll(); >bsPlacesBindingSource.DataSource = tblPlaces; > >This works but each time the number of SelectionChanged events that are >fired increases, which I don't understand. It's almost as though behind >the scenes the number of rows is quietly increasing each time, but that >doesn't appear to be the case because the grid continues to display the >correct number of rows (eventually!) > >I'm wondering from your reply if there is a better way to refresh the >data that my bindingsourece or datagridview is using? > >Many thanks again for your help > >Simon changes to the data source, then set the DataSource back to what it was before. I don't use TableAdapters so I don't have any experience with them. |
| | #6 (permalink) |
| | Re: DataGridView firing way to many SelectionChangedEvents! Please OK - I'll give that a shot - thank you Simon |
| Linkbutton firing every other time issue | .NET General | |||
| Help sound firing out external and headset. Annoying my vanpool. | Vista General | |||
| firing noise in wmp11 | Vista General | |||
