Vista - help with pc
Old 08-12-2008   #1 (permalink)
ineedhelp
help with pc
my computer will shut down and startup perfectly.....but if i unplug it it
wont come back on for 3-8 hours three times when it started up after 3-8
hours it said "firmware has detected a CMOS battery failure......firmware has
detected a CMOS checksum error.....firmware has detected that the time and
date have not been set"
Old 08-12-2008   #2 (permalink)
Jeff Gaines
Re: help with pc
On 12/08/2008 in message
>has
This is a programme's group so not the best place to seek help.
However, the error message you see is probably correct, you need to
replace your CMOS battery.
Jeff Gaines Damerham Hampshire UK
Tell me what you need, and I'll tell you how to get along without it.
Old 08-12-2008   #3 (permalink)
ineedhelp
RE: help with pc
can someone tell me how to fix this problem????-ineedhelp
Old 08-12-2008   #4 (permalink)
ineedhelp
Re: help with pc
i dont know how it got here but i already replaced it still does it
> >has
Old 08-12-2008   #5 (permalink)
PvdG42
Re: help with pc
"ineedhelp" <ineedhelp@xxxxxx> wrote in message
news:CFCEA83A-5D9F-412B-B192-9109C05BA0E7@xxxxxx
Try resetting your CMOS to defaults, then see if the error message goes
away. If that doesn't help, either find a forum on general PC
troubleshooting or take your computer to a competent local repair shop. As
you were told previously, this group is for .NET programming topics.
The closest thing in the Microsoft public groups would be an appropriate
Windows group, which you can find by following these instructions:
As you appear to be using a web interface, start here to find an appropriate
group:
http://www.microsoft.com/communities...s/default.aspx
Click the + beside your language. then scroll down to Windows. In Windows,
open the category for your version of Windows, then find a group there to
post in.
Old 08-12-2008   #6 (permalink)
Dick Grier
Re: help with pc
You have a hardware problem. If replacing the battery didn't solve the
issue (try a different battery -- again), you may have a problem with the
actual BIOS ROM(RAM). If so, the only practical solution is a new
motherboard. Just, IMO.
Richard Grier, MVP
Hard & Software
Author of Visual Basic Programmer's Guide to Serial Communications, Fourth
Edition,
ISBN 1-890422-28-2 (391 pages, includes CD-ROM). July 2004, Revised March
2006.
See www.hardandsoftware.net for details and contact information.
