Vista - DirectoryEntry without using admin user: how to check if account'sexpired
Old 08-14-2008   #1 (permalink)
Big Charles
Hello,
Programming in VS2003-ASP.NET 1.1, I have this problem: Using
DirectoryEntry and without any admin user, how can I check if a domain
account, that try to login, has expired?
Scenario: User load web application and login using account and
password of the Active Directory.
But user account of ActiveDirectory has expired (or password could be
expired). For security reason, we don't want to use any account with
admin privilegies for connecting through AD. So if user account "jdoe"
with password:"jdoe_password" try to login, how to determine if
account has expired.
Code:
Dim Domain As String = "DOMAINXXX"
Dim sUserName="jdoe": Dim sPassword="jdoe_password"
Dim myEntry As System.DirectoryServices.DirectoryEntry =
New System.DirectoryServices.DirectoryEntry("LDAP://" & Domain,
sUserName, sPassword,
System.DirectoryServices.AuthenticationTypes.Secure)
myEntry.Username = sUserName
myEntry.Password = sPassword
Dim mySearcher As
System.DirectoryServices.DirectorySearcher = New
System.DirectoryServices.DirectorySearcher(myEntry)
Dim myResult As System.DirectoryServices.SearchResult
mySearcher.Filter = "(&(objectCategory=person)
(objectClass=user)(userPrincipalName=" & UserName & "*))"
Dim x as String = myResult.Properties("sAMAccountName")(0) ''<-- it
gets 'jdoe'
Dim y as String = myResult.Properties("userAccountControl")(0) ''<--
it gets Nothing
I don't think it's impossible, or that you have to use an admin user
to get that (if you have to use an admin user for connecting to AD,
what about security?)
Thanks
Add user - lost the task bar on admin user General Discussion
How to set Admin password from an admin user account Vista General
Launching process with Admin Credentials with out prompting user for Admin password PowerShell
User - Admin - Super Admin Vista account administration
Wat is the difference between Built it Admin and Admin User Vista General
