Vista - problem with enum in web custom control
Old 08-17-2008   #1 (permalink)
rony_16
i wrote a web custom control, that adds a search option to list box.
on of the properties are the position of the textbox that serves are
search, the position is Enum (Up, Down).
the code looks like that :
namespace SearchList
public Enum SearchListLoacation
Up,Down
[DefaultProperty("Text"),ToolboxData("<{0}:SearchList runat=server></
{0}:SearchList>")]
public class SearchList : WebControl,INamingContainer
private SearchListLocation _SearchLocation;
public SearchListLocation SearchLocation
get {return _SearchLocation;}
set {_SearchLocation = value;}
(HTML)
<div>
<cc1:SearchList ID="SearchList1" runat="server" AutoPostBack="True"
SearchLocation="Down" />
</div>
when i try to compile the code (custom control + website) i receive
the following msg ;
SearchList.SearchList does not contain a definition for
'SearchListLocation' .
the project is framework 2 version.
what can cause this kind of error ?
Rony,
Old 08-18-2008   #2 (permalink)
Marc Gravell
Re: problem with enum in web custom control
It sounds like either a reference that hasn't updated, or confusion
because of the naming. Is that the exact error message? I would have
expected the message to match the property, not the type - after all, to
get the type (from just the property name) it must have resolved the
type! Can you confirm whether both the aspx and the error message are
verbatim?
I also have my doubts about the wisdom of names that lead to
"SearchList.SearchList" - that is a recipe for confusion.
Marc
Old 08-18-2008   #3 (permalink)
rony_16
> verbatim?
> Marc
Thanks,
is seems that the designer can't understand when the namespace and the
class are with the same name.
Old 08-18-2008   #4 (permalink)
Vista Business x64
Did you cut and paste the code? There is a typo if you did. Your enum:
Up,Down
Old 08-31-2008   #5 (permalink)
rony_16
On Aug 19, 3:47*am, breitak67 <gu...@xxxxxx-email.com> wrote:
> public Enum SearchListL*_oac_*ation
> Up,Down
> breitak67
no i re-typed it from another computer (closed network)
