Problem Writing file to CD
  1. #1
    cjamps Guest
    I have HL-DT-ST RW/DVD GCC-4240N. It seems to be a problem though with either
    the cd rom drive or the operating system because whatever CD I put in it does
    not recognize as a CDR or a CDRW eventhough it does read from them. It tells
    me that there is no disc in the drive and to please insert a writable CD into
    the drive. I am running a DELL INSPIRON 1100. Any help or advice on this
    would be appreciated. Thanx.
  2. #2
    PvdG42 Guest
    Re: Problem Writing file to CD
    "cjamps" <cjamps@xxxxxx> wrote in message
    news:7876603E-87B2-45E7-A93F-7E13B6805CC2@xxxxxx
    > either
    > does
    > tells
    > into
    Either way, asking about optical drive issues in a .NET programming group is
    unlikely to get you much assistance. Try asking in a group for you version
    of Windows. Here's how to find it.
    As you appear to be using a web interface, start here to find an appropriate
    group:
    http://www.microsoft.com/communities...s/default.aspx
    Click the + beside your language. then scroll down to Windows. In Windows,
    open the category for your version of Windows, then find a group there to
    post in.
Problem Writing file to CD problems?
Writing to IE or a file won't work Mike H VB Script 4 16 Jun 2009
Writing File to CD ROM SAC VB Script 9 16 May 2009
Writing Number to Text File: Type Problem? Todd Walton VB Script 4 04 Feb 2009
writing out to file Braden C. Roberson-Mailloux PowerShell 3 18 May 2008
Writing to a file with out-file or export-csv Marco Shaw PowerShell 1 07 Nov 2006
