| | [VC++ 2008 EE] problem with opening a compiled program. Hi. I am going to send my copy of message from different group where i did not get answer yet.[VC++ "Hello I have a problem with VC++ EE. Sorry if it's very trivial problem but I honestly just have begun with programing in windows. I have made an application in VC++ .NET EE and I would like it to work on every computer not only those which has Visual C++ EE installed. The other computer has installed Framework .NET 3.5 and i have simply copied program from <project folder>\Debug (or Release) and system says: "This application has failed to start because the application confuguration is incorrect. Reinstalling application may fix this problem." What do I need in other this application to work? Regards =)" |
| Detect which version of Visual Studio compiled a program | .NET General | |||
| Mircosoft Accounting Program 2008 | Vista mail | |||
| Problem running VS2008 Compiled EXE | .NET General | |||
| Re: Opening a PROGRAM???? | Vista performance & maintenance | |||
