Vista - Project Templates
Old 09-10-2008   #1 (permalink)
Jeff Gaines
Project Templates
I tried asking these questions in the Windows Forms group but have had no
response so I will try again in these 2 groups.
I am using VS2008.
I have created a 'base project' which includes references I commonly use
and a form inherited from my own base form. I also added some links to my
library file to try and make it easily available in all my projects.
Although I can export/save the template, when I create a new project based
on the template all the links point to a temporary folder, not to where my
library file lives. Is there a way round this, perhaps trying to persuade
VS to use absolute or relative links?
Also I have a base form which has code to save/restore its position. It
also has a Status Strip with a Status Label on it to show messages. The
modifiers of the Status Strip are set to Public.
I can't access the Status Strip from the inherited form, either in the
designer or programmatically. What else to I need to do to make it visible
in the inherited form please?
Jeff Gaines Damerham Hampshire UK
I can please only one person per day. Today is not your day.
Tomorrow, isn't looking good either.
templates Microsoft Office
PowerShell Visual Studio project template wiped out all other templates PowerShell
In any project, Can't we refer classes directly, (without addingphysically in the project)? .NET General
Updated supplemental set of Windows Vista Media Center project templates now availabl Vista News
Microsoft Advances Its Project Management Technology and the Project Management Profession Vista News
