Vista - Null parameter problem
Old 09-10-2008   #1 (permalink)
E. Kwong
I have a function that takes two arguments
Public Function CheckThing(ByVal b As Boolean, ByVal s as String) As
String
The function is called from inside a FormView control like this:
<%#CheckThing(Eval("flag"),Eval("myfield"))%>
Everything works fine except when myfield has a null value: I'll then get
an error saying something like ".can not convert DBNull to string.."
What's the best way to handle situation like this? Thanks.
I'm using VS2005, and SQL Server database.
Old 09-10-2008   #2 (permalink)
Vista Business x64
Re: Null parameter problem
There area number of ways. First, if you are okay with deciding there should be no nulls in this field from the db, modify the sproc that returns the data to replace myfield with ISNULL(myfield,'') in the T-SQL select statement.
There are ways to handle it in the app code as well. I have been using C#.NET since 2003, so I will have to pull up VS and figure out the equivalent VB.NET syntax. I'll post back later with that.
Old 09-10-2008   #3 (permalink)
Vista Business x64
Replace myfield with:
IIf(Eval("myfield") Is System.DBNull.Value, "", Eval("myfield"))
You can also change the parameter type to allow a DBNull to come across and handle it in the CheckThing function.
Script parameter problem PowerShell
Re: "Error: 'null' is null or not an object" when trying to view video Vista performance & maintenance
Gotcha: $null to [string] IS NOT $null PowerShell
Problem with WMI in WinPE - null: Invalid Syntax Error Vista installation & setup
How to best control parameter attributes and parameter parsing in your own scripts? PowerShell
