| | Problem running VS2008 Compiled EXE Hi I recompiled previous VC6.0 C++ MFC project with VS2008 Evaluation It could run release at the system with the VS2008 installed. But it gives "Application has failed to start because the application configuration is incorrect..." Error when i try to run at target systems. I have already installed the Dot Net 3.5 at the target System. Even if i create a MFC C++ solution from VS2008 it gives the same error. -- regards |
| | Re: Problem running VS2008 Compiled EXE Unless you statically link to the libraries your app uses, you will need to deploy the libraries to target machines that will run your app. Deployment (C++) http://msdn.microsoft.com/en-us/library/zebw5zk9.aspx Mark -- Mark Salsbery Microsoft MVP - Visual C++ "beauwlf" <beauwlf@xxxxxx> wrote in message news:48c87a2d_2@xxxxxx Quote: > > Hi > I recompiled previous VC6.0 C++ MFC project with VS2008 Evaluation > It could run release at the system with the VS2008 installed. But it gives > "Application has failed to start because the application configuration is > incorrect..." Error when i try to run at target systems. > I have already installed the Dot Net 3.5 at the target System. > > Even if i create a MFC C++ solution from VS2008 it gives the same error. > > > > > > -- > regards > |
| Code compiled on old visual studio. Running VS2008 Pro now | .NET General | |||
| IE doesnt start when running a VS2008 web project | .NET General | |||
| [VC++ 2008 EE] problem with opening a compiled program. | .NET General | |||
| Upgrading from VS2008 standard to VS2008 Pro? | .NET General | |||
| upgrade from VS2008 standard to VS2008 pro- options? | .NET General | |||
