Vista - Problem installing and registering activex into vista machine.
Old 09-12-2008   #1 (permalink)
Vista Ultimate x64
Hi All
I have created a Activex using C# 2.0 and i am deploying it to user's machine through WebLogic app server.The activex gets downloaded and registerd perfectly in case of all XP machines.
But now i am testing the same Activex download on Vista machine,It failed to install if the UAC is enabled.
If i disabled the UAC then it gets insalled.(Don't know whether registerd to machine or not)
and when it invoked for my JSP application then it fails to function.
I have also signed the Activex locally and imported the certificate to my IE provided by server.
I want it to work as in XP ,no UAC disable stuff also.
How can i achieve this goal without tampering any thing in my machine settings.
Thanks
___Das
Problem Installing ActiveX Controls .NET General
Installing / Registering Canon Multipass F80 Vista Driver Vista hardware & devices
Error installing ActiveX cab on Windows Vista Vista General
Error installing ActiveX cab on Windows Vista Vista security
