Vista Tutorial - Does the XMLDocument.Load(System.IO.Stream) method load the whole
Old 09-12-2008   #1 (permalink)
Shawn Sesna
Guest
The description of the XMLDocument.Load method doesn't quite answer the
question. When passing in a FileStream object to the Load method, does it
load the entire document into memory? For example, if I have a 1 gigabyte
file, would the Load method attempt read the entire 1 gigabyte file into
memory when using a FileStream object?
Old 09-12-2008   #2 (permalink)
Jeroen Mostert
Guest
Re: Does the XMLDocument.Load(System.IO.Stream) method load the whole
Yes. The kind of stream doesn't matter, actually, it will pull data from the
stream until it's read a complete document.
Quote:
> For example, if I have a 1 gigabyte file, would the Load method attempt
> read the entire 1 gigabyte file into memory when using a FileStream
> object?
It wouldn't actually read all of the file into memory, it would read it
piecewise and construct an in-memory representation of the XML document it
represents while it's doing so. This will end up quite a bit larger than 1
GB, actually. This is why XmlDocument is unsuitable for very large streams.
XmlReader and XPathNavigator are light-weight alternatives.
J.
Windows Update Won't Load--gets error-"This page failed to load" Windows Updates
HELP! "Unable to load on Stream" Vista Games
CPU load about 50% when system is idle Vista General
how to reduce system load? Vista performance & maintenance
System Properties Fails To Load Vista General
