Vista - Problems Activating XP Pro
Old 09-13-2008   #1 (permalink)
MickyP
Ok, so I have a HP xw4200 with a valid XP Pro registration key, in fact it
came on it already installed.
I then bought a second-hand computer that needed Wnidows installed on, but
that also had it's own valid registration key.
Now, like an idiot, when installing XP Pro on the second computer, I
accidently put the registration key from the xw4200, but I realised before it
could activate it online, so I reinstalled XP Pro putting in the correct
registration key this time.
Now I've reinstalled XP Pro on the xw4200, but it won't activate it anymore
with the legitimate registration key.
I'm hoping I haven't ruined it, so can anyone help me or guide me in the
right direction? I just want to be able to get both computers running right
with their own valid XP Pro registration keys.
Old 09-13-2008   #2 (permalink)
PvdG42
Re: Problems Activating XP Pro
"MickyP" <MickyP@xxxxxx> wrote in message
news:635FCA41-98C0-4923-95AC-5BE52FC2854C@xxxxxx
> it
> anymore
> right
Use the phone activation option, then wait through the options until you get
to speak to a human. Explain the situation.
In future, your Windows questions should go to a Windows group. Here's how:
As you appear to be using a web interface:
http://www.microsoft.com/communities...s/default.aspx
Click the + beside your language. then scroll down to Windows. In Windows,
find the Windows XP category . Open it and find a group for your
question.
Old 09-13-2008   #3 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Don't know much about XP - you might be better posting to an XP forum.
You could try contacting Microsoft - they may give you a new product key
you get to the toll free number as follows ( with vista - don't know about xp - but see if it's similar)
Activate Vista by Phone
Seem to remember hearing with XP you could save the wpa and wpa.bak files to a cd then copy them back in safe mode after reinstall to save calling microsoft to reactivate - from that extrapolate there might be 2 sets of these on your second computer ?
Hope that helps
SIW2
Problems Activating/Changing .Net 3.0 General Discussion
Re-activating Vista problems Vista General
Problems activating windows vista Vista account administration
Problems Re-activating Windows Vista Vista General
Problems Activating Windows Vista installation & setup
