Vista - Re: Microsoft Wireless Laser Mouse 8000
Old 09-18-2008   #1 (permalink)
PvdG42
"ace-poker" <ace-poker@xxxxxx> wrote in message
news:7B9B694A-03C3-4507-875C-7B8508CAB1D4@xxxxxx
Quote:
>I have been using a MS Laser Mouse 8000 with Vista for some time now with
>no
> problems other than very occasionally the mouse is not detected during
> boot
> and I have had to re-start.
> The problem I now have is that with the Bluetooth transmitter plugged into
> the USB windows will not boot past the 'blue screen' - if I remove the
> transmitter and install cable mouse everything boots normally.
> So far I have tried the following:-
> Deleted and re-installed mouse software
> Hit F8 at boot and repaired start up
> Tried different USB ports for the transmitter
> Windows is current with all updates
> Ocassionally windows will boot with the laser mouse and when it does
> everything works perfectly.
> Any ideas anyone?
Asking about Vista issues in this .NET programming group is unlikely to get
you a lot
of help.
Try posting in an applicable group like this...
As you appear to be using a web interface:
http://www.microsoft.com/communities...s/default.aspx
Click the + beside your language. then scroll down to Windows. In Windows,
find the WindowsVista category . Open it and find a group for your
question.
Problem Microsoft Wireless Laser Mouse 8000 - Bluetooth Vista hardware & devices
Microsoft Wireless Laser Mouse 8000 Vista hardware & devices
Microsoft Wireless Laser 8000 Bluetooth Mouse Vista hardware & devices
Quicken 2007 H&B and Microsoft wireless laser mouse 8000 in Vista Vista hardware & devices
