| | Problem opening .ini files. Hello, I use windows XP ver.2002, Service pack 2. I am getting a very strange error. I am unable to open any file with extension".ini" If I create any text file, type some text and save it with extension ".ini" and try to open it using notepad (or by double clicking), it gives following messege: "The file name, directory name, or volume label syntax is incorrect" But same file opens properly if I try to open using "Wordpad". What is wrong ? Is there any problem with Notepad setting ? Please reply. Thanks in advance. Lokee |
| | Re: Problem opening .ini files. You should try to locate a newsgroup with the name "windows" in it. This is a group for DotNet programmers/developers. "lokee" <lokee@xxxxxx> wrote in message news:CAC09F8C-3088-4A2D-B7F7-7022AE32F3A6@xxxxxx Quote: > Hello, > > I use windows XP ver.2002, Service pack 2. > I am getting a very strange error. > > I am unable to open any file with extension".ini" > If I create any text file, type some text and save it with extension > ".ini" > and try to open it using notepad (or by double clicking), it gives > following > messege: > > "The file name, directory name, or volume label syntax is incorrect" > > But same file opens properly if I try to open using "Wordpad". > > What is wrong ? Is there any problem with Notepad setting ? > > Please reply. > > Thanks in advance. > > Lokee |
| | Re: Problem opening .ini files. Sorry, i selected General Discussion. But the problem I mentioned below arised in my VB.Net application. I need to read some data from a .ini file. After struggling for a long time i tried to open tht file manually and then I realized i can not open it. "sloan" wrote: Quote: > > You should try to locate a newsgroup with the name "windows" in it. > > This is a group for DotNet programmers/developers. > > > > > "lokee" <lokee@xxxxxx> wrote in message > news:CAC09F8C-3088-4A2D-B7F7-7022AE32F3A6@xxxxxx Quote: > > Hello, > > > > I use windows XP ver.2002, Service pack 2. > > I am getting a very strange error. > > > > I am unable to open any file with extension".ini" > > If I create any text file, type some text and save it with extension > > ".ini" > > and try to open it using notepad (or by double clicking), it gives > > following > > messege: > > > > "The file name, directory name, or volume label syntax is incorrect" > > > > But same file opens properly if I try to open using "Wordpad". > > > > What is wrong ? Is there any problem with Notepad setting ? > > > > Please reply. > > > > Thanks in advance. > > > > Lokee > > |
| | Re: Problem opening .ini files. It sounds like the file association is messed up for ini files. Look at this link and see if it truly is using Notepad to open them. http://www.microsoft.com/windowsxp/u.../filetype.mspx "lokee" wrote: Quote: > Sorry, i selected General Discussion. > But the problem I mentioned below arised in my VB.Net application. > I need to read some data from a .ini file. After struggling for a long time > i tried to open tht file manually and then I realized i can not open it. > > "sloan" wrote: > Quote: > > > > You should try to locate a newsgroup with the name "windows" in it. > > > > This is a group for DotNet programmers/developers. > > > > > > > > > > "lokee" <lokee@xxxxxx> wrote in message > > news:CAC09F8C-3088-4A2D-B7F7-7022AE32F3A6@xxxxxx Quote: > > > Hello, > > > > > > I use windows XP ver.2002, Service pack 2. > > > I am getting a very strange error. > > > > > > I am unable to open any file with extension".ini" > > > If I create any text file, type some text and save it with extension > > > ".ini" > > > and try to open it using notepad (or by double clicking), it gives > > > following > > > messege: > > > > > > "The file name, directory name, or volume label syntax is incorrect" > > > > > > But same file opens properly if I try to open using "Wordpad". > > > > > > What is wrong ? Is there any problem with Notepad setting ? > > > > > > Please reply. > > > > > > Thanks in advance. > > > > > > Lokee > > > > |
| | Re: Problem opening .ini files. Have you rebooted recently? That's a weird issue. Try Reboot. Under Windows Explorer....... Tools / Folder Options / File Types and remap "INI" to notepad. I don't know, its really weird. There used to be a "Take Ownership" command in NT...I don't know what it might be (if it exists) in XP. "lokee" <lokee@xxxxxx> wrote in message news:4FE17E76-9E42-4874-95B0-FA4934366D7F@xxxxxx Quote: > Sorry, i selected General Discussion. > But the problem I mentioned below arised in my VB.Net application. > I need to read some data from a .ini file. After struggling for a long > time > i tried to open tht file manually and then I realized i can not open it. > > "sloan" wrote: > Quote: >> >> You should try to locate a newsgroup with the name "windows" in it. >> >> This is a group for DotNet programmers/developers. >> >> >> >> >> "lokee" <lokee@xxxxxx> wrote in message >> news:CAC09F8C-3088-4A2D-B7F7-7022AE32F3A6@xxxxxx Quote: >> > Hello, >> > >> > I use windows XP ver.2002, Service pack 2. >> > I am getting a very strange error. >> > >> > I am unable to open any file with extension".ini" >> > If I create any text file, type some text and save it with extension >> > ".ini" >> > and try to open it using notepad (or by double clicking), it gives >> > following >> > messege: >> > >> > "The file name, directory name, or volume label syntax is incorrect" >> > >> > But same file opens properly if I try to open using "Wordpad". >> > >> > What is wrong ? Is there any problem with Notepad setting ? >> > >> > Please reply. >> > >> > Thanks in advance. >> > >> > Lokee >> >> |
| | #6 (permalink) |
| | Re: Problem opening .ini files. Hi sloan and Family Tree Mike, I did exactly the same as mentioned in the link, but in File Types option, when I select INI option, it correctly shows Opens with: Notepad. But still file does not open with notepad. "sloan" wrote: Quote: > Have you rebooted recently? > > That's a weird issue. > > Try > Reboot. > > Under Windows Explorer....... > Tools / Folder Options / File Types > and remap "INI" to notepad. > > I don't know, its really weird. > > There used to be a "Take Ownership" command in NT...I don't know what it > might be (if it exists) in XP. > > > > > "lokee" <lokee@xxxxxx> wrote in message > news:4FE17E76-9E42-4874-95B0-FA4934366D7F@xxxxxx Quote: > > Sorry, i selected General Discussion. > > But the problem I mentioned below arised in my VB.Net application. > > I need to read some data from a .ini file. After struggling for a long > > time > > i tried to open tht file manually and then I realized i can not open it. > > > > "sloan" wrote: > > Quote: > >> > >> You should try to locate a newsgroup with the name "windows" in it. > >> > >> This is a group for DotNet programmers/developers. > >> > >> > >> > >> > >> "lokee" <lokee@xxxxxx> wrote in message > >> news:CAC09F8C-3088-4A2D-B7F7-7022AE32F3A6@xxxxxx > >> > Hello, > >> > > >> > I use windows XP ver.2002, Service pack 2. > >> > I am getting a very strange error. > >> > > >> > I am unable to open any file with extension".ini" > >> > If I create any text file, type some text and save it with extension > >> > ".ini" > >> > and try to open it using notepad (or by double clicking), it gives > >> > following > >> > messege: > >> > > >> > "The file name, directory name, or volume label syntax is incorrect" > >> > > >> > But same file opens properly if I try to open using "Wordpad". > >> > > >> > What is wrong ? Is there any problem with Notepad setting ? > >> > > >> > Please reply. > >> > > >> > Thanks in advance. > >> > > >> > Lokee > >> > >> > >> > > |
| Problem opening zip files | Vista General | |||
| office 2004 for Mac/ problem opening files | .NET General | |||
| opening files | Vista music pictures video | |||
| Problem opening .rtf files with ms works | Vista General | |||
| Navigation When Saving Files, and Opening mht files from Browser | Vista file management | |||
