| | Creating a Custom Enumerator in a Base Class I have a base class MyBaseClass, and several classes that inherit from it: MyClass1, MyClass2, etc. The base class implements IEnumerable(Of IMyBaseClassRow). The base class has a DataTable object that contains different data depending on which of MyClass1, MyClass2 are instantiated. I want to be able to iterate through the rows of the data table using For Each on my derived classes retrieving a custom row with properties specific to that child class. I found this article http://blog.falafel.com/2007/01/30/C...Iterators.aspx which alludes to the technique, but doesn't go all the way to showing how to derive custom row classes with the properties. I am also doing this in VB, so I don't have Yield Return. Therefore, I am having to code this all by hand. I want all the enumeration stuff in the base class, so that I don't have to reproduce it in every derived class, but I have one stumbling block. This is my implementation of Current() in my base class: Private ReadOnly Property Current() As IMyBaseClassRow Implements System.Collections.Generic.IEnumerator(Of IMyBaseClassRow).Current Get If m_CurrentRow = -1 Or m_CurrentRow > m_MyBaseClass.DataTable.Rows.Count - 1 Then Throw New InvalidOperationException End If Return New MyBaseClassRow(m_MyBaseClass.DataTable.Rows(m_CurrentRow)) End Get End Property The problem is that this can only return a new MyBaseClassRow, and not a MyClass1Row. Therefore, when I do For Each row As MyClass1Row in MyClass1Instance ... Next the compiler is happy, but it fails at runtime with an InvalidCastException on the For Each line. I think I need to override something in my MyClass1 or MyClass1Row class, but I'm not sure what exactly, or how. If this problem makes sense to anyone, please feel free to chip in. Any and all help welcome. TIA Charles |
| | Re: Creating a Custom Enumerator in a Base Class I think I've cracked it. In my base class MyBaseClass, I have created a must override function that returns an object of the type I want, i.e. Protected MustOverride Function GetIMyBaseClassRow(dr As DataRow) As IMyBaseClassRow In my concrete class, I then override this function: Protected Overrides Function GetIMyBaseClassRow(ByVal dr As System.Data.DataRow) As IMyBaseClassRow Return New MyClass1Row(dr) End Function Finally, Current() in MyBaseClass becomes this: Private ReadOnly Property Current() As IMyBaseClassRow Implements System.Collections.Generic.IEnumerator(Of IMyBaseClassRow).Current Get If m_CurrentRow = -1 Or m_CurrentRow > m_MyBaseClass.DataTable.Rows.Count - 1 Then Throw New InvalidOperationException End If Return GetIMyBaseClassRow(m_MyBaseClass.DataTable.Rows(m_CurrentRow)) End Get End Property It allows the base class to call the derived class to get an object of the actual type required. I hope this helps someone. If anyone has another solution, I am still very interested to hear. Charles "Charles Law" <blank@xxxxxx> wrote in message news:OWpQYelGJHA.4408@xxxxxx Quote: >I have a base class MyBaseClass, and several classes that inherit from it: >MyClass1, MyClass2, etc. > > The base class implements IEnumerable(Of IMyBaseClassRow). The base class > has a DataTable object that contains different data depending on which of > MyClass1, MyClass2 are instantiated. > > I want to be able to iterate through the rows of the data table using For > Each on my derived classes retrieving a custom row with properties > specific to that child class. I found this article > > http://blog.falafel.com/2007/01/30/C...Iterators.aspx > > which alludes to the technique, but doesn't go all the way to showing how > to derive custom row classes with the properties. I am also doing this in > VB, so I don't have Yield Return. Therefore, I am having to code this all > by hand. > > I want all the enumeration stuff in the base class, so that I don't have > to reproduce it in every derived class, but I have one stumbling block. > This is my implementation of Current() in my base class: > > Private ReadOnly Property Current() As IMyBaseClassRow Implements > System.Collections.Generic.IEnumerator(Of IMyBaseClassRow).Current > Get > If m_CurrentRow = -1 Or m_CurrentRow > > m_MyBaseClass.DataTable.Rows.Count - 1 Then > Throw New InvalidOperationException > End If > > Return New > MyBaseClassRow(m_MyBaseClass.DataTable.Rows(m_CurrentRow)) > End Get > End Property > > The problem is that this can only return a new MyBaseClassRow, and not a > MyClass1Row. Therefore, when I do > > For Each row As MyClass1Row in MyClass1Instance > ... > Next > > the compiler is happy, but it fails at runtime with an > InvalidCastException on the For Each line. > > I think I need to override something in my MyClass1 or MyClass1Row class, > but I'm not sure what exactly, or how. > > If this problem makes sense to anyone, please feel free to chip in. Any > and all help welcome. > > TIA > > Charles > > |
| Creating a class in a HTA | VB Script | |||
| Base class defined and initialized variables loose initialization in subclass. | .NET General | |||
| Using a Delegate to Simulate Invoking Events in Base Class | .NET General | |||
| Creating a WMI class | PowerShell | |||
