Vista - Help with connection string
Old 09-21-2008   #1 (permalink)
Benedictum
I have an Access database in remote server with a url of e.g. -
http://www.myserver.com The database is located in a folder named "/data".
What is the connection string be?
Old 09-23-2008   #2 (permalink)
Paul Musso
Re: Help with connection string
Benedictum a utilisé son clavier pour écrire :
Hi Benedictum,
http://www.connectionstrings.com is your friend
Look at this url : http://www.connectionstrings.com/?carrier=access2007
It will help you
Paul Musso
Old 09-23-2008   #3 (permalink)
Andrew Morton
> "/data". What is the connection string be?
You really don't want to expose an Access db like that. Write an asp.net
page (or a web service) that accepts a request, creates a parameterized
request to the db, then sends back an appropriate reply.
Andrew
Old 09-25-2008   #4 (permalink)
Benedictum
Andrew's suggestion surely has merits. I may have to do what he suggested.
However, his suggestion poses a little problem for me - I have not done this
before I am sure I will learn this with just a little studying and
asking for help. In the meantime, you guys can give me a start. Thanks guys.
--B
"Andrew Morton" <akm@xxxxxx-press.co.uk.invalid> wrote in message
news:6jsi8fF4sp75U1@xxxxxx
> Andrew
Getting Remote Assistance Connection String on vista. Vista General
SQL Server connection string for deployment ? .NET General
SQL connection string encoded in a Uri? .NET General
Web.config and Connection String Management .NET General
ASP connection string to SQL2005 VB Script
